Old 06-22-2011, 02:08 PM
70rs's Avatar
70rs 70rs is offline
Originally Posted by 505camaro69 View Post
Can you repost with the pictures available?
X2
I would like to see these too.
Have you installed these in any second gen camaros yet?
Eric
Old 06-22-2011, 03:58 PM
almcbri's Avatar
almcbri almcbri is offline
There are pics of mine on my photobucket. They will not fit brp mounts and clear the box. I Havent tried them on my 68 with s&p plates.
1968 Camaro LS1/T56, Hotchkis Springs, Tubular Arms, AFCO sway bar, C5 brakes, VWW 18" V40's http://s14.photobucket.com/albums/a3...1968%20Camaro/
Old 07-22-2011, 09:38 AM
1HTBRRD's Avatar
1HTBRRD 1HTBRRD is offline
Wondering what part # you used for the MSD wires? I was looking through Summit and they all seemed to have the straight spark plug boot which would hit the #5 and #7 primary tubes on the driver's side.
On a side note, I am running these headers on a 5.3 in a stock subframe with stock power steering and stock upper control arms if anyone wants to see photos of fitment.
-John
1962 Nova, LS1/ T56, DSE Mini tubs and subframe connectors, Church Boys 4 link, Viking coil overs, C6 brakes
Old 07-23-2011, 07:22 PM
almcbri's Avatar
-John
I wold like to see them! What motor mounts are you using and are they the stock location motor mounts? I hope mine clear, but I am still a month away from getting the motor back in.
Old 07-25-2011, 12:31 PM
tango68ss's Avatar
tango68ss tango68ss is offline
Here's my '68 vert with DynaTech LSx headers. I love 'em!!
Take a look at my build link (pcis #416-430) for better/ more detailed pics of the header fitment.
TC
Tango
Link to my Build:http://screaminperformance.com/gallery/index.html
Old 07-27-2011, 08:38 PM
1HTBRRD's Avatar
I used the transadapt plates and motor mounts (http://www.summitracing.com/parts/TRD-4595/).
The pictures don't do the headers justice because my power steering lines are in the way. The headers fit great and they were easy to retrofit to my old big block exhaust.
There is about 1/2 an inch between the driver's side upper comtrol arm and the primary tube although it's hard to tell from the photos.
Old 08-09-2011, 07:06 PM
almcbri's Avatar
They fit good! I need to trim a small piece of the SBC mounts. I am using the carshop mounts.
Old 08-10-2011, 03:35 PM
1HTBRRD's Avatar
TC
I ended up using the msd multi angle plug wires with my headers. Just like I thought, the #5 and #7 spark wires are up against the primary tubes. I was able to bend the msd multi angle plug ends and then zip tie them up so they would not touch...but I recommend to anyone else using these headers to get the right angle plugs that will give you more clearance. The driver's side pic above clearly shows how there is not much real estate around the #5 and #7 spark plugs.
Old 09-01-2011, 08:46 AM
boostin05blacks boostin05blacks is offline
Im looking to get a set of these and have s&p plates. Can anyone confirm if they will or will not work before I pull the trigger? Thanks Steven
Update:01/27/12
So i pulled the trigger and bought these. As far as price goes they cannot be beat..they fit very well with my s&p mounts. Clear the steering box with ease the only issue I see if I have to ground a little material off of my drivers engine mount but that no big deal..here are some pictures.
Old 04-11-2013, 09:16 AM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
Update:01/27/12
I know this is an old thread , but I have a couple of questions ...... Is there header made that has better ground clearance...? These appear to hang down a little bit too much for my liking. Does anyone have any suggestions : I am doing a stock subframe , stock Power steering gear box , and it has factory air conditioning in a 69 . I am going to use a 6.0 and LS-3 heads is my plans.
