Old 09-19-2011, 09:21 AM
CAMAROBOY69 CAMAROBOY69 is offline
My neighbor and I loaded up the Mustang and trailered it to his shop on Saturday. We spent 12 straight hours working on the long list of items for the car. Also worked on it a little yesterday.
This is what my neighbor and I accomplished over the weekend.
1. Removed the old gas tank which surprisingly leaves a massive hole in the trunk. The top of the gas tank is actually the trunk floor. lol
2. Plasma cut out the body at the rear of the car for the Saleen S281 Exhaust. This is only a rough cut and will be cleaned up later.
3. Installed the 40 series Flowmasters and Saleen S281 exhaust. True dual exhaust front to rear. We even welded shut the middle between the saleen S281 tips.
4. Removed the old rusty front frame pieces and welded in new ones. This took several hours and was a messy disaster. I love how solid the car is now with the frame pieces. Plus seeing the new floor board, the new exhaust, new mufflers, and the new frame pieces looks awesome under the car.
5. Welded the tranny crossmember support bracket to the floor for extra strength and stability.
6. Installed both transmission lines to the radiator.
7. Started working on running the power steering lines to the new power steering pump.
8. Repaired a bad spot in the rear driver frame. I plan to replace these rear frames eventually.
9. Removed the original shifter because it was very sloppy.
10. Removed all the unnecessary brackets and lines from under the car.
11. Welded and repaired a crack in the tranny crossmember.
12. Installed the driveshaft. Direct bolt in!
13. Repaired the distributor coil bracket and bolted the coil to the front of the engine instead of on top of the intake.
14. Shortened and re-arranged some of the wires on the engine for a cleaner look and for better organization.
15. Changed the oil and oil filter
16. Removed the front carpet so it wouldnt catch on fire while welding in the front frame pieces. haha
17. Installed a driveshaft loop between the exhaust pipes for safety plus it added a some more stability to the exhaust.
18. Installed a threaded rod for the new Edelbrock air cleaner
Still a lot to do before its drivable but we made some massive progress this weekend and the front frames were a huge step forward to make the car stronger. Yesterday we started the Mustang with the new Saleen S281 exhaust. Heather loves the way it sounds but its too quite for me. Once we get headers installed next year it will be louder which should make both of us happy.
Adam_______Offical Car Name "ILLUSION"
383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels,Hydratech Hydraboost
ILLUSION Website
--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
ILLUSION Website
Old 09-19-2011, 09:42 AM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Good progress. What size pipe is the Saleen exhause tips piece? Looks pretty small.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 09-19-2011, 09:48 AM
Thanks. I was very happy with the progress especially on Saturday. Installing the front frames wasnt even on the list but once I had the car up on the lift, I decided we should just go for it.
I think the Saleen tubing at the end is about 1 3/4". Yes its small. But since this is a bone stock 74 302 with only maybe 200hp I figure it will be fine for now. Next year when we install the headers I will decide if I want to increase the size of the rear Saleen tubing.
ILLUSION Website
