Old 09-25-2011, 03:34 PM
Tincup's Avatar
Tincup Tincup is offline
Car is looking great, I wouldn't worry to much about the color of the primer, done properly, your painter should lay down a coat of sealer prior to painting. The sealer can be tinted if necessary, if not, it will at least provide a uniform base.
Old 09-26-2011, 05:13 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Good to see the updates Wayne. Nice to see your car sitting in your garage.
Keep us posted buddy.
Old 09-26-2011, 06:27 PM
I cleaned up the parking brake pedal assembly last night. I used Safest Rust Remover, I soaked it over night and just rinsed with water and dried it. It came out pretty good. I'm going to coat it with satin clear and satin black. Thats the original paint on there. Let me know what you think.
Here are the before pictures.
Now heres what they look like tonight.
Not too shabby aaaaahhh! Tonight I'm soaking the clutch, brake pedals and the support. I need to order more rust remover.
Old 09-26-2011, 07:30 PM
Ralphlovs72chev's Avatar
Ralphlovs72chev Ralphlovs72chev is offline
What did you use and from were did you get it? It did a very good job. Your car is coming along nicely. A
Old 09-26-2011, 07:37 PM
Thats the name of it Safest Rust Remover. Here's the link. I got it online. Its always done a good job for me. http://www.ultraone.com/ Check out the videos they have of it working. Its amazing. I have some of their degreaser but I haven't tried it yet.
Old 09-26-2011, 09:40 PM
70rs's Avatar
70rs 70rs is offline
Wow! That stuff is amazing! No scrubbing or anything? Just soak it?
Eric
Old 09-27-2011, 09:51 AM
No scrubbing. You just have to keep it wet, either submerge it or make it flow over the part with a small pump. Once I didn't have enough to cover the part so I took a piece of thick cloth and wet it and just pored it over the cloth every so often to keep it wet and it still worked.
Old 09-27-2011, 05:06 PM
tones2SS's Avatar
Looks good Wayne. Keep up the good work man!
Old 09-27-2011, 06:15 PM
Thanks Tony. Tonight I cleaned the clutch, brake pedals and the support. I just noticed even that is date coded.
And after.
And the date code.
Old 09-27-2011, 06:18 PM
SWAPMEETCRAZY's Avatar
SWAPMEETCRAZY SWAPMEETCRAZY is offline
Wayne ,give us a clue as how much of this stuff is needed to do the parts like U did--Do U reuse or is it DOA after use??.........jim
