Old 10-10-2011, 09:11 AM
CAMAROBOY69 CAMAROBOY69 is offline
I dont plan to do much else to the car this year with the cold weather coming and lack of money. But this is what I accomplished over the weekend.
-Welded in 8 custom seat brackets for driver and passenger seats. The seats set up nice and high. Ergonomically engineered for Heather.
-Welded in temporary crossbar for the 5 point seatbelt harness mockup.
-Installed front and rear carpet.
-Installed driver and passenger racing seats.
-Installed 5 point racing seat belt harness for driver seat. Still need a 5 point harness for passenger seat.
-Extended the plug wire for the neutral safety switch by 6 inches to add more clearance. 4 total wires, a plug, and 8 crimp adaptors.
-Removed passenger valve cover to check for light rocker noise. I think a push rod might be plugged or a lifter is plugged. I will resolve this next year when I install a new 4 barrel carb and intake. Then I can check all the lifters and push rods to make sure they are getting proper oil.
-Worked on the wiring for the Alternator. Its still not working yet so I need to take the alternator down to make sure it works.
Adam_______Offical Car Name "ILLUSION"
383 Stroker, Stock cast heads, T-56 tranny, 4.11 gears, 2002 T/A dash, 4th gen interior including seatbelts, power lumbar seats, 18" Budnik Wheels,Hydratech Hydraboost
ILLUSION Website
--------------My Car on Lateral-g.net----------- Need something designed?-AdFabDesign
