Old 10-18-2011, 05:49 PM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
Dropped the LS1 back in the chasis! It fits much better now. Now the chassis can suport an LS1 or a SBC! No mods needed! Anyway, here's the pics. I think I'm done for a while...
No Shop, No Money, No Time.... No problem!
Old 10-24-2011, 12:21 PM
After reading through Badmotorfinger's thread, I thouht I'd share a clip from my 377 running right before I pulled it out. I built this motor in 1986 and it still purr's!
https://www.youtube.com/watch?feature...&v=MVFgb1UG4L0
Old 11-08-2011, 07:37 AM
I'm on the cheap so I grabbed a set of OBX headers off of a wrecked 4th gen. Spent a little time moving a tube or two and corrected the angle issue on the drivers side and Viola! Custom headers that fit my 1st gen home made chassis. Here's what I did.
Old 11-08-2011, 08:42 AM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
You're making some good progress. Keep at it!
Curtis
Old 11-08-2011, 09:36 PM
daemon2's Avatar
daemon2 daemon2 is offline
Did you make the lower coilovers mounts on your IRS, or are they available online?
Daemon2
Old 11-09-2011, 08:11 AM
No Kit on the rear, I made all of it.
Old 11-09-2011, 08:14 AM
I've made everything on this car, most of it with a 4" cut off wheel. I had bracket parts laser cut for me from an autocad sketch that I did. If you read through this entire post you'll see where I commented about moving the IRS up in the chassis, that happened in the gap in the posts from '09-'10. I moved it up about an inch and a half. I like the way it sits much better now. I'm really getting the itch to drive this car in the spring so I'm trying to surge ahead on it this winter. Plan to pull the front sub and get it powdercoated over the winter while I finish the firewall. I still have lots of wiring to do, but the Brakes, Clutch and fuel are all plumbed. Still need to plumb the powersteering.
Old 11-29-2011, 03:20 PM
Started to the wireing on the LS, not decided yet where to mount the PCM. May bolt it behind the inner fender or inside under the dash, not sure yet. Also spent way to much time fabricating these "flanges" that I'll weld into the firewall to suport the front subframe downbars. No machine shop here, just a bunch of hole saws and a drill press, but I think they turned out ok. Here's some pics...
Old 12-13-2011, 04:22 PM
Spent the last week tracing out and marking wires (just to be sure) and removing what I don't need from the engine harness. Wasn't too bad, just time consuming. Now I've moved on to the power distribution blocks that will supply power to all the components under the hood. Most people just buy relays and make some homemade bus, but I had all the panels and the wires so I thought I'd try and see if I can make it work for a cleaner install. I think I'm going to mount the PCM in the center of the dash where the old dask speaker would have been and bring the harness out through the trans tunnel above the bell housing, should hide almost all the wires. I'll mount the fuse boxes in the same location as the 4th gens, and tuck the wires up into the fender and through the firewall which should also be hidden. Here's some pics!
For all you mechanical guys, the new custom bent sway bar arms came in yesterday, after the wires are done, I'll pull the front sheet metal and mount the sway bar (hopefully for the last time!)
Old 12-13-2011, 05:14 PM
coolwelder62's Avatar
There is no way I would try and figure out all that LS wiring on mine own.Man you are brave.
