Old 10-19-2011, 08:20 AM
68/Camaro's Avatar
68/Camaro 68/Camaro is offline
Default Keisler-Tremic-TKO 600 Stuck in 5th ?
Was at the NSRA-Southeast Street Rod Nationals this past weekend and driving the "Evade" all three days back and forth from the house 45 minutes each way it was a great weekend and even took home a Award Pick of the Show presented by (ISCA) International Show Car Association. I was about 4 miles from the house went to down shift in fourth gear and would not go? had a serious grind trying to shift the shifter sounded like it was shifting in each gear however its fricking stuck in 5 gear had no other choice but to drive it home in 5th I now i burned the hell out of the clutch! but was able to make it home, on Monday morning called Keisler and left a voice mail for Shafi Keisler and e-mailed him since I bought the complete TKO-600 package from them its been three days and NO phone call! or NO e-mail what great service! need help?
Thanks,
Bill
Bill Panouses
Evade Camaro http://www.facebook.com/pages/Evade-...71454739554636
www.evadecamaro.com
Old 10-19-2011, 10:10 AM
68/Camaro's Avatar
Wow no reply?
Ive been Contemplating for the past 8mo swapping out the TKO and step up to the T-56.. Now since I will be changing the whole clutch it might be a no brainier any advice?
Bill Panouses
www.evadecamaro.com
Old 10-25-2011, 05:07 PM
71 RAT's Avatar
71 RAT 71 RAT is offline
Bill
Just ran across your post, have you had any luck with your problem yet? I have some rebuilding experiance with TKO,s and 3550's
Old 10-25-2011, 06:35 PM
Beegs's Avatar
Beegs Beegs is offline
Originally Posted by 71 RAT View Post
Bill
Are you on 43 in Deerfield?
Bryan
Old 10-27-2011, 10:48 AM
71 RAT's Avatar
Bryan
I live on Haynes Rd. Sounds like you are in the area?
Old 10-27-2011, 11:54 AM
senor_Camaro senor_Camaro is offline
sounds like you have a bad synchro, hopefully the rebuild kit shouldnt be expensive unless you still have warranty on the transmission.
Old 10-27-2011, 12:42 PM
Sieg's Avatar
Sieg Sieg is offline
Bill - I'd give Jim Goodlad a call at Hurst Drivelines and see if he'll help trouble shoot the issue. 760-859-6635
FWIW - I'm very satisfied with my close ratio T56 Magnum, there are no rpm gaps.
Old 10-27-2011, 12:52 PM
Beegs's Avatar
Bryan
Yup...right up the road from you in Strafford. I assume you rebuild transmissions?? Do you work from home? Nice to see other NHampsters on this forum....welcome aboard!!
Bryan
