Old 10-27-2011, 10:41 PM
Northeast Rod Run's Avatar
Northeast Rod Run Northeast Rod Run is offline
That frame is awesome, but my real question is........... How deep was that damn storage locker?
TJ Ragucci
http://www.northeastrodrun.com/
Old 10-31-2011, 09:53 PM
Dam that looks awesome!
Old 10-31-2011, 10:10 PM
tgvettes tgvettes is offline
That frame is just a work of Art
Tonny
Tonny
1980 Volvo 262 C Pro Touring Project
Old 11-14-2011, 11:06 PM
INTMD8's Avatar
INTMD8 INTMD8 is offline
Trying to decide on wheel/tire sizing so I borrowed these to test fit.
Sizes are-
Front 18x8 4.5 backspace 245/45/18
Rear 20x10 5 1/8 backspace 275/35/20
I like the width and backspace but I think overall tire diameter could go up about an inch.
Old 12-31-2011, 04:08 PM
INTMD8's Avatar
I found the floors! Exhausting and horrible job.
Old 12-31-2011, 04:09 PM
INTMD8's Avatar
Floors back together, spare tire well removed.
Old 12-31-2011, 04:10 PM
INTMD8's Avatar
Did a few more things on the car, such as testing tire fitment. Looks like it will be fine on the rear, obviously too wide for the front but I threw it on there just to get an idea of height. 275/55/17, 28.91 diameter. Wish I had the rear fender skirt here, I can't remember how the latch worked or if it will interfere with the tire, I think it swung straight down but not sure.
What I do know is that a roadside tire change will be next to impossible as I need to drop the rear-end down to get the tire over the brakes. Going to have to think a bit on that one.
Brakes are just a dual 9in booster and disc brake master/proportioning valve. 3.5-1 pedal ratio. Boxed in the firewall area with 11 gauge steel.
Engine/trans are in place. I need to make motor mounts (and new trans crossmember) as I set the engine back 4.5inches from where RS put it. The engine and trans oil pans are 1.25 below the frame rail. Still a bit over an inch off the ground when the suspension is on the bump stops but I may raise up the front of the engine slightly to gain some clearance but I wanted to keep driveline angles shallow.
