Closed Thread
Old 12-12-2011, 12:12 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Ugh! I hate reading about threads like this. Especially when my car is being worked on. You brain starts running all the possibilities....
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 12-12-2011, 12:18 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
yup, not alot of shops do it right. It takes time to set-up, mock up and measure correct before cutting and/or installing. Shops have a hard time billing for this time consumiing portion of any custom install. So, what do they do.... Well cut corners because the bid was at "X" amount.
You do have an "Ace" in your cards.... TCI is the referral and consulting party. You should be fine.
Old 12-12-2011, 12:46 PM
orangevert's Avatar
orangevert orangevert is offline
A reputable company will just eat it and make things right, Sounds like you will be taken care of.
Every one wants everything to run smooth, In business it dosent always go that way, It's all how you handle it..
Good luck and hope things work out for you..
Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 12-12-2011, 12:48 PM
raguemoe's Avatar
raguemoe raguemoe is offline
At this point I'm not in a hurry, I just want it fixed. I think I'm one of those special people were if something can go wrong it will. I'm sure Jon has done many installs & hundreds wheel combos with no problems. If Jon can get it taken care of in a reasonable time, there will be no hard feelings. I understand that sh*t happens and we have to move on. I'm not here to bash anyone, just didn't like the response I was getting and wanted to make sure I wasn't crazy.
Btw the wheels look great & the Speedtech setup is 100% better than what I had on the car.
Old 12-12-2011, 02:08 PM
DriverzInc DriverzInc is offline
Ya, but you posted it anyway, and no matter what, it still sucks.
Closed Thread
