Old 12-16-2011, 04:36 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Originally Posted by brgable View Post
man this isn't sounding very good...lol. most 67's and 68's I've seen have 9.5" but I have seen some with 10" on there without a minitub I just didn't get the wheel dimensions from them. the 67 I saw with 11" wheels with that size backspacing were 17" wheels how much of a difference is that from an 18? the wheels i have on it now are 15x8 with 275/60/15 tires with a 1" spacer and the 11" wheels i saw looked to sit in the same spot in the fender well as the wheels on my car now. I will not be lowering the car because I like the car to have some space between the tired and fender plus I am running super comp hooker headers that already hang low enough with stock height springs under the car. my car has the stock 5 leaf springs on the rear to give you and idea of the ride height now. sorry to ask so many questions or sound repetitive but it really helps hearing from people in the know before I go out and spend a lot of money on wheels and tires that don't fit well at all. again, thanks for the help guys!
Assuming your going to run the same height and width tire on an 17 or 18" rim(ie 275/40/17 or 275/35/18) the 17" rims would allow for slightly less clearance. Likely the sidewalls on the 17" tires would have a little more bulge to them.
What size tires was the guy that said he had 11" wide rims running? I'm guessing the guy was either mistaken about the size of his rims or the tires he was running were really not wide enough for an 11" wide wheel. Also there is no way you can fit 6.75" of backspacing with a stock width rear end. DSE's minitubs move the tub 2.75" inboard. Most minitubbed, stock width rear end guys are right around 8" of backspacing. Not sure how he could fit only 1.25" less backspacing in a space that is 2.75" smaller? If his rear end was 2" wider than stock he MIGHT be able to fit a 10" wide wheel with 6.75" of backspacing.
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 12-18-2011, 08:07 PM
brgable brgable is offline
Jason he has a video on youtube of his 67 I'll put the link on here if you want to take a look. I appreciate your feedback and help I'm new to the pro touring scene for camaro's here's the youtube link:
https://www.youtube.com/watch?v=ONZrEutChdE
he said they are front 17/7 billet specialties w/ 225 / 40/17 tires rear 17x11 w/ 6 3/4 " back spacing 315/35/17 2" lowering block on rear mono leafs, front springs cut to desired ride height.
Old 12-19-2011, 02:57 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
Jasons is correct. After looking at the video, you can clearly see those wheels are not tucked inside the fender wells and if he were to give viewers a good rear shot they would probably look like Dumbo ears sticking out.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 12-19-2011, 05:00 PM
JMitch19's Avatar
I agree they don't tuck. I guess you could fit 18x20 if you don't mind 10" of tire sticking out. My point is even if you could find an 18x20, a tire to fit it, and your okay with them sticking out you still will only do so with a max of 5.75" of backspacing. This is assuming he it's using a stock width rear which he may not be, and in that case maybe he is using 6.75" of backspacing.
I just don't want to see someone order wheels thinking these specs would work and then be very disappointed when they have to run 1-1.25" spacer/adapter.
Jason Mitchell
Old 12-19-2011, 05:41 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
11" isn't gonna happen as other have already said.
However, a 10" wheel will tuck inside of a 68 fender if you roll the fender lips really well. I ran a 10" wheel on my car for a while. When I switched wheels I really regretted lettting the sales guy talk me into a 9" rim...
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 12-19-2011, 08:36 PM
JustinB's Avatar
JustinB JustinB is offline
Done tons and tons of wheels on 67-68's. Some 67-68's can squeeze a 10" if you roll the fenders and you get lucky. I have a 68 now, measured and measured, it will not take a 10. The 18x9.5 with a 275 is going to take a bunch of work to get to fit without rubbing and the backspace is spot on. Wish I could have got the 9" to help pull the tire in a little more and it would fit the car. I have a 69 as well, should easily take a 10" according to all the forum jockeys right? Nope. Rubbed all over the place at the ride height I wanted. Built a set if 19x9 for the rears. Fit like a glove with the exact same amount of "wheel lip" as the 19x10 and more than I could get out of the Rushforth 18x10's. Basically at the end of the day, you are going to be running a 275/40/18 tire. Does it really matter if its in on a 18x9 or 18x10?
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 12-20-2011, 06:25 PM
what back spacing would you recommend for an 18x10? also, the tire I was considering running was a 245/50/18 I saw a 68 with those on 18x9.5 and they looked great. I'm not so much trying to go with the "tucked" look for my car. my car will be purely a driver and very very little track time so I kind of prefer the stock or near stock ride height with the suspension. my car is an original big block rs/ss so cutting on the car is out of the question, I've just put my original parts (engine, trans, brakes) in storage so I will have them when I decide to go back original. can't thank you guys enough for your input this website is awesome!
