Old 01-06-2012, 08:46 AM
KPC67's Avatar
KPC67 KPC67 is offline
Originally Posted by Sonar Chief View Post
I was looking into using AME and their 4 link under my 67, that way I will have a stronger foundation (factory rails gone) and should not have to cut into their rails. I emailed them about the mini-tub and clearance - no answer yet!
Michael
Thats a good idea.
I ended up with only 1/4" of frame rail left.
I don't have a good picture of it, I will take one tonight and post it up for you.
Kevin Carter
Old 01-06-2012, 11:46 AM
Sonar Chief's Avatar
Unhappy AME 4 Link Update
Originally Posted by KPC67 View Post
Thats a good idea.
Yeah, that would be great to see. I just don't like the idea of cutting the frame rail and leaving a 1/4 inch? That can't be as strong as OEM!
Just got off the phone with AME and the 4 link frame is made to fit 335mm inside the wells (no cutting their frame), the drawback for me at least, I can't use my 12 bolt. The upper link mounts can't be welded on a 12 bolt, so .... guess I'll sell this one and save for a nine inch housing.
Michael
Old 01-06-2012, 11:52 AM
Ron in SoCal's Avatar
Hey Michael/Kev - I was also concerned about how little frame rail was left after the mini tub - even though we boxed the frame rail - so we ended up putting in 1/4" steel plate on the inside of the raii. There's a pic in this post:
https://lateral-g.net/forums/show...62&postcount=3
Of course, the AME rails avoid all this...
Ron in SoCal
69 Camaro in progress
Old 01-06-2012, 12:00 PM
Ron ... you bent up the 1/4" steel plate or you welded a plate on the inboard side of what was left of the rail? Can't tell from those pictures.
Thanks for chiming in.
Michael
Old 01-06-2012, 12:15 PM
Michael
Welcome Michael! We welded to the inboard side. I guess you could bend 1/4" steel plate, but I didn't see the need...
Ron in SoCal
Old 01-06-2012, 05:41 PM
KPC67's Avatar
Michael, I couldn't get any decent pictures tonight, my camera died.
I actually cut all of the frame out just leaving the sheetmetal on the inboard side of it, and bent up a 1/4" steel plate for the close out. I still think it will be plenty strong, and I plan on boxing it in once i get the car on a rotisserie.
Kevin Carter
Old 01-06-2012, 05:47 PM
KPC67's Avatar
Michael[/QUOTE]
It depends on what you want to do. I just bought a nine inch from DSE and the housings start around $900; or you can source one from a junk yard, the mid seventies trucks are a good place to start.
Kevin Carter
Old 01-06-2012, 07:12 PM
Thumbs up Frame Cut for Tubs
Ron ... looks like Kevin bent the 1/4" plate version. WOW, I guess there isn't much frame left. Thanks for the Pictures Kevin.
