Old 01-06-2012, 12:00 PM
Sonar Chief's Avatar
Hey Michael/Kev - I was also concerned about how little frame rail was left after the mini tub - even though we boxed the frame rail - so we ended up putting in 1/4" steel plate on the inside of the raii. There's a pic in this post:
Ron ... you bent up the 1/4" steel plate or you welded a plate on the inboard side of what was left of the rail? Can't tell from those pictures.
Thanks for chiming in.
Michael
Old 01-06-2012, 12:15 PM
Ron in SoCal's Avatar
Michael
Welcome Michael! We welded to the inboard side. I guess you could bend 1/4" steel plate, but I didn't see the need...
Ron in SoCal
69 Camaro in progress
Old 01-06-2012, 05:41 PM
KPC67's Avatar
KPC67 KPC67 is offline
Michael, I couldn't get any decent pictures tonight, my camera died.
I actually cut all of the frame out just leaving the sheetmetal on the inboard side of it, and bent up a 1/4" steel plate for the close out. I still think it will be plenty strong, and I plan on boxing it in once i get the car on a rotisserie.
Kevin Carter
Old 01-06-2012, 05:47 PM
KPC67's Avatar
the drawback for me at least, I can't use my 12 bolt. The upper link mounts can't be welded on a 12 bolt, so .... guess I'll sell this one and save for a nine inch housing.
Michael[/QUOTE]
It depends on what you want to do. I just bought a nine inch from DSE and the housings start around $900; or you can source one from a junk yard, the mid seventies trucks are a good place to start.
Kevin Carter
Old 01-06-2012, 07:16 PM
Default 9 Inch
Michael
It depends on what you want to do. I just bought a nine inch from DSE and the housings start around $900; or you can source one from a junk yard, the mid seventies trucks are a good place to start.[/QUOTE]
Kevin ... AME has a pretty good price on their 9 inch with the brackets welded in place, of course they want you to buy the WHOLE kit at once 3700 bucks - saves money and you only have to pay for shipping once.
So.... thinking.
Old 01-06-2012, 07:25 PM
Thumbs up Update 1/6
Some Garage Time Didn't feel too motivated to think tonight, so I did the mundane job of cleaning up the front floor pans, and did that ever make a mess. Got all the glue off and the surface rust in the toe board, seems there was water sitting under the carpet/ underlayment, go figure!
Had to be done.
Using a circular disc to clean the floor, not bad!
Passenger toeboard. Little bit of surface rust, that **** will buff out!
Michael
Something everyday is better than nothing.
Old 01-07-2012, 03:36 PM
Cool Update 1/7
UPDATE 1/7 Did some clean work on the Camaro today. Used POR Chassis Black over the POR15 silver, first I had to break the skin of the silver with a gray scotch brite pad and then used my work garage and heat to give the dash and the door frame a couple thin coats. I think the sheen will fad a little.
Now the back to the dirty work, finish the floor!
Good for another 45 years.
Dash POR Chassis Black
Ditto
Michael
Something everyday!
Old 11-07-2014, 08:41 AM
Korny Korny is offline
Anyway you can update your pics in your first posts in this thread? They are not showing and I take it those pics were of what the car looked like when you got it. Would like to see that.
Old 11-07-2014, 08:54 AM
I emailed ImageShack and they are no longer supporting the OLD ImageShack .... so I guess they are gone. I have all the pixs and when I get some time I'll try and upload the old pixs.
Thanks for asking .....
Old 11-07-2014, 09:59 AM
Cool. Post them up when you can. Even edit your first post and I'll check it out when they are up.
