Old 01-28-2012, 03:39 PM
coolwelder62's Avatar
Ricer,Give me a call on Mon. Maybe I can answer your questions once I figure out what you'r wanting to do.1.785.594.7481Scott.
Old 01-29-2012, 10:03 AM
ricer ricer is offline
i purchased the spindles already...brakes will be here tomorrow, car should be here early next week so hopefully it will all work together.
565 twin 80mm 67 Firebird
545ci FFR MKIII Roadster
Old 01-29-2012, 02:35 PM
If you need any help feel free to call.
Old 01-29-2012, 11:01 PM
tandk22 tandk22 is offline
Wilwood listed they only guarantee hiedts drop spindals will fit and say they should fit with others. I used hiedts with the 14" wilwood kit and they fit perfect. I know you bought but letting people know. Todd
Old 04-03-2012, 06:47 AM
so i finally got around to installing the spindles and i can spin the castle nut to just barely finger tight while not being so low on the ball joint that the cotter pin won't be within the nut.
Has anyone ever had to add washers/shims/etc to the ball joint to be able to get the appropriate torque on the castle nut while still being able to have the cotter pin nested inside the nut? I am thinking 1-2 possibly 3 flat washers should do the trick but just wanted outside opinions as well.
