Old 01-29-2012, 07:49 AM
ks71z28 ks71z28 is offline
good info Mark. My IR setup was perfectly happy being lean at cruise but really liked a richer idle a/f, no matter how I adjusted the blades. Had a big solid roller too which affected that.
How does an average guy monitor each cylinder individually to take advantage of this feature? I can see that on an engine dyno with headers that have pyro's or a/f bungs at each pipe. I'm thinking most of the guys never get their engines on an engine dyno and do their tuning on a chassis dyno or on the street and wouldn't have that type of exhaust to be able to individually monitor a cylinder. Would an infrared temp gun on the tubes give enough info? I do remember that feature and played with it a little, but I didn't have a real good way to monitor things other than a temp gun. This was a blown small block, not an IR setup but we were chasing a problem.
The Holley Dominator system has individual fuel trim, you will need to tune on a dyno with 8 o2's to perfectly set them, or use 8 EGT's, we use an IR thermometer to see if any cylinders are leaner or richer, and adjust there. IR systems are tricky and usually not worth the hassle, we did 2 over the last few years, although they look great!
www.customworksperformance.net
530 864-5846 2nd gen performance
Old 01-29-2012, 07:57 AM
Really? That's a pretty big statement - pretty "broad"....
Mine run and work perfectly as do my buddies (4 other 8 stack systems of various ECU's and motor combos).
Old 01-29-2012, 08:04 AM
Mine run and work perfectly and do my buddies (4 other 8 stack systems of various ECU's and motor combos).
mine did too. With a .650 lift [email protected] solid roller you could let the clutch out in first gear at 900 rpm idle speed and even without touching the throttle it was smooth as silk. No jumping back and forth in gear at that low of an engine speed. And there's pretty much nothing that looks as cool as an IR setup.
Old 01-29-2012, 03:38 PM
supremeefi supremeefi is offline
I agree, I did a 427 windsor Ford, made 621 hp with 9.0:1 compression and an 8 stack, had 535lbft of torque at 3500rpm.
Being able to adjust timing helps a bunch. But I don't agree that you need a dyno, it's nice but not absolutely necessary imo.
And I know Greg had a bad experience but I do cals via the internet all the time, it makes a difference if you know what you're doing.
Mark
Engine builder and tuner.
Old 01-29-2012, 04:12 PM
Back when I first starting doing this -- there was no internet!
I agree that you can tune via emailing files.
Old 01-29-2012, 07:31 PM
They can be made to run well, but the drivability can be a bit fussy. Plumbing in a vacuum port to each cylinder is important to run a IAC, and also equal out the tip in throttle. 8 blades can be tough to sync at all throttle positions. We run tripple Solex carbs on our GT-2 240z, but that car always sees at least 1/2 throttle at all times!
Old 01-29-2012, 08:27 PM
Inglese's new(er) cast manifold for Small Block Chevys has a huge cast in plenum in the valley area... so vacuum is "plumbing free"... and the large volume smoothes out the pulses.
I run NO IAC on either of my motors... no need for it.
Old 01-31-2012, 05:21 AM
shaun8541 shaun8541 is offline
Did you do that 427 with the EZ EFI or the XFI?
Old 01-31-2012, 05:18 PM
Neither one, Accel Gen 7.
That's why I mentioned what I did. The XFI can't tailor the individual cylinder trim by load/rpm. It's an all or nothing calibration with the XFI and doesn't exist at all on the EZ.
Compos, thank you for the comment, I think
Yes there are too many mediocre tuners out there, with every make of system. I know I've run across too many.
And yes I do gaurantee my tuning. But I ask all the right questions about the application BEFORE I sell anybody anything. And I'm not concerned about not making any money on the self tuning stuff, it's not my primary source of income anyway. If you look closely at the software there are better and average systems around.
But the nice thing about some of the better systems out there is that they will help an otherwise ill advised combination to some degree, i.e. another 427 Ford I did with a 249/[email protected] on a 110 hyd roller cam. It came to me with a Mass AirFlo system, self tuning right? Ran like crap, even after 3 chip changes and sending the ECM back twice. After swapping to a non self learning system, it idles at 750 rpm all day and runs great.
Mark
Old 01-31-2012, 08:12 PM
That is what most of the sales / tuner guys DON'T do.... they just sell or install and think they can figure it all out... SO KUDOS TO YOU MARK!
