Old 02-05-2012, 03:40 PM
daemon2's Avatar
daemon2 daemon2 is offline
Yea, I've pretty much moved away from any existing limitations of the original. Preserving the original unibody frame or internal body work wasn't a priority for me.
It's custom all the way now.
Daemon2
Old 02-05-2012, 03:46 PM
daemon2's Avatar
Default Why?
This may help explain why:
When I opened up the frame rails all I found was rust, the construction makes them prone to collecting water and causes them to flake apart from the inside out.
I will end up with a custom frame under this car, so far I am about 150lbs lighter with the new frame and floor than what I cut out. Also a big advantage for where I am headed.
I should also note that this car, although appearing in great condition when I started, was nowhere near original.
Daemon2
Old 02-05-2012, 03:52 PM
Iamtheonlyreal1 Iamtheonlyreal1 is offline
Banned
Ah, I got it.. LOL I totally understand, and was really just curious how much of the original unibody front rails and body structure you were keeping.. From the looks of the unit, it didnt appear you were keeping much.. ha ha
Old 02-08-2012, 05:05 PM
daemon2's Avatar
Default reveal
The rendering arrived, thanks to Shawn@Mascoll Designs!
I have taken some cues from the 2009 Voxx rendering, its a shame no one has built that car.
I wanted more width and I think it came together very well.
Daemon2
Old 02-08-2012, 05:48 PM
Banned
I am building that car (Project Changling)... LOL I have done about everything, and am hitting about 90 percent of the Vox Rendition. My glass company has started on the full glass treatment, including the full greenhouse roof/back glass and quarter glasses, and that should put the rendtions reality over the top..
Your rendition is very very cool, and you definitely got the correct stance. But you are going to find the front end is off a bit.. I ran into alot of issue with the front nose of this car, and the Vox Rendition.. There are so many compound curves that have to be dealt with, and in the drawing it is much easier than in reality, because the compound curves are not easy to translate in the drawing..
One question, do you plan on buiding up the trunk to surface? In the rendition, it is more squared off, and doest match up with the actual compound curve of the factory body. It looks as though you built up the trunk panel, to take away from the height of the fins?
Old 02-09-2012, 07:43 PM
daemon2's Avatar
definately a lot of compound curves on this car, you're right. The deck lid may come up, I will see how things look back there after I fit the wheels in.
Thanks for the comments.
Daemon2
Old 02-12-2012, 05:23 PM
daemon2's Avatar
One of my most frustrating weekends with the car since I got the thing. Finished some work on the rear crossmember but found more rust inside the rear rocker that I have to deal with now.
I suppose the good news is it will all be solid after I replace everything....
Daemon2
