Old 02-07-2012, 06:49 PM
SicMonte's Avatar
SicMonte SicMonte is offline
Default Front Lower Ball Joint Leaking...no kidding!!
While working on my prop valve I noticed that something was leaking onto both of my front tires. It turned out to be my lower ball joints!! Have any of you heard of the grease liquefying in the lower ball joint? I did weld them in about a year ago and have since re-greased them with the Valvoline Syn grease that I have always used. Is there a way to drain these things??
Old 02-07-2012, 08:31 PM
David Pozzi's Avatar
Pump new grease in it to flush the old stuff out. Keep pumping till you see fresh grease.
http://www.PozziRacing.com
Old 02-07-2012, 08:37 PM
Drive it
Old 02-07-2012, 08:44 PM
SicMonte's Avatar
Drive it
I have been driving it...and I just noticed this. I have no idea how long it has been doing this.
Old 02-07-2012, 09:03 PM
Everything looks brand new. Grease will drip, watch your grease gun after a month b
Old 02-07-2012, 09:06 PM
SicMonte's Avatar
Everything looks new b/c I clean the underside quite often! I installed these control arms and new suspension set up this time last year. I'll keep an eye on it.
Old 02-07-2012, 09:26 PM
It's to clean man, get out there and dirty her up.
Old 02-07-2012, 09:40 PM
SicMonte's Avatar
like this??
Old 02-07-2012, 10:53 PM
Hell yes! Your car clearly works.
Old 02-08-2012, 07:22 AM
Put a zirk in that threaded hole that looks to be empty on the side in the one photo.... that could be your source of leaking.
