Old 02-08-2012, 08:19 PM
SicMonte's Avatar
SicMonte SicMonte is offline
Wow...I totally forgot the pics on how to put these darn coilovers together!!!!
Pic of the seperated shocks and springs, which are 200lb springs.
Much better pics of the upper and lower brackets in the G Body kit.
Upper spring cup/retainer
Lower spring cup/retainer/spanner
Old 02-08-2012, 08:28 PM
SicMonte's Avatar
This is a pic of the upper eye of the shock where the adjusters are. You have to fully turn in the adjuster to allow the upper spring retainer to fit over it. The one on the left is fully extended while the one on the right is fully turned in.
You can see that groove there on the base of the shock's head. A retainer ring slides into that groove and allows the upper spring retainer to rest on it and not fall out.
That retainer ring is in the bag that is next to the shock in this picture.
Old 02-08-2012, 08:34 PM
SicMonte's Avatar
Once the upper retainer is in place all you need to do is slide the spring over the shock and screw on the lower spring cup/retainer/spanner. Once you have the bottom spanner at the spot where you would like it this little set screw keeps the spanner in place. The screw uses a 4mm allen wrench to tighten.
You want to start the intsall process with the bottom spanner just touching the springs so that they wont fall out of the upper spring cup/retainer. This gives the spring 0 preload and is the ideal spot to start at.
Old 02-09-2012, 06:08 AM
Bryce Bryce is offline
Nice write up! It looks like ridetech did a great job helping you out along the way.
Old 02-26-2012, 05:15 PM
89 RS's Avatar
89 RS 89 RS is offline
I'll second that on nice write up! That's good stuff right there, I'd like to know how it rides now. You have done some cool stuff to that G-Body, look forward to seeing more, nice work man.
Corey
1989 Camaro RS
Old 02-26-2012, 05:20 PM
SicMonte's Avatar
It ride so much better than my older set up. No more bounce from the rear end!!!
I have a full build thread on pro-touring.com...have you seen it?
Look up "Project Sicmonte"
Old 03-04-2012, 12:17 PM
89 RS's Avatar
Good deal, I had seen bits and pieces, but I went back and looked at the whole thread. Good stuff.
Corey
1989 Camaro RS
