Old 02-09-2012, 09:51 AM
I had TWO BeCool's leak -- in my Nomad -- never again.....
I use AutoRad now. Actually - I'd use ANYTHING over a BeCool...
Old 02-09-2012, 09:54 AM
Track Junky's Avatar
I'm running the $1200 BeCool also and so far its treated me and the car well. I'm running 620 hp at the crank.
Greg, which BeCool did you use?
Gaetano Cosentino
Old 02-09-2012, 12:43 PM
Whatever crossflow they sell for a tri five chevy... polished etc...
Both leaked in the exact same place -- where they GLUE their tanks on... I no longer use anything where the metal is glued... They call it epoxy -- I call it GLUE. No thanks to those tanks!
Old 02-09-2012, 01:36 PM
How long ago? 1956? Ha even Ron Davis was using epoxy 10 years ago. I agree though, I wouldnt buy a brand new epoxied radiator.
Old 02-09-2012, 04:56 PM
69znc's Avatar
69znc 69znc is offline
Default I have had both Davis and now AutoRad
THe Davis and AutoRad both are excellent, and not inexpensive. radiators. I ran duel fans on both controlled by my ECM I got the larger diameter tubing in my new AutoRad. The target market for Davis seems to be a bit more industrial for HD racing and the AutoRad same quality and cooling but the extra touch to the street look and finish.
my 2 cents
Peter
Old 02-11-2012, 07:26 AM
tyoneal's Avatar
tyoneal tyoneal is offline
Good ideas on the Radiators.
I had never dealt with a BT sbc before, and this issue was baffling.
Do you think that a "Cross Flow" radiator with the killer Mark VIII Fan would still be a viable option?
Those fans with a proper housing on it I believe to be about the strongest around.
Ty
Project, "EnGULFed"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
"Chester's '65"
1965 Buick Riviera
Old 02-11-2012, 07:45 AM
Fan CFM is only important when you're not moving... and it's more important if you're running A/C... and if you add an automatic transmission to that... then you have a lot of heat to deal with.
Personally I like dual fans -- and I've been controlling them on my cars with the Spal PWM fan controller. It adds cost - but really works well - especially if you're running A/C.
