Old 02-17-2012, 06:47 AM
KPC67's Avatar
KPC67 KPC67 is offline
Originally Posted by mpozziCPL View Post
I see overspray ...
"Must clean off!!"
Mary Pozzi
That will buff out!
I love how you continue to upgrade this car, and keep it fresh.
Kevin Carter
Old 02-18-2012, 09:49 PM
James OLC's Avatar
As promised – some more detailed pics… David got the housing installed in The OLC today so we’ll try to have some more final assembly pics soon. I have to say that the more I see this setup, the more I like it!
An emergency brake might be cool one day – if nothing else it’s great to have the option.
An assembled end
A complete end less the drive plate
The drive plate
Bearing
Bearing
Assembled with axle, less drive plate
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 02-18-2012, 11:49 PM
Them are some great lookin parts...
Old 02-19-2012, 07:42 AM
KPC67's Avatar
Good job on having some up close pics on the floater. It looks like a very nice piece.
Kevin Carter
Old 02-20-2012, 09:41 AM
67ragtp 67ragtp is offline
Hey James,
The car looks like its coming along great. I was wondering if you could tell me who's hyd throw out bearing you are using on the centerforce DYAD set up and are you running a magnum t56? I tried to pm you but your box is full.
Thanks Rich
Old 02-20-2012, 12:58 PM
James OLC's Avatar
Hey Rich - sorry about the PMbox... It's cleared out now.
We're going to use a stock GM slave cylinder. The last one lasted four years, two transmissions, three clutch rebuilds and a bunch of abuse... Plus Centerforce said that's what they recommend
And yes - its a T-56 Magnum transmission.
James
1969 Camaro - Dusty
Old 02-23-2012, 09:37 PM
James OLC's Avatar
So David got the rear end assembled and installed in the OneLapCamaro last weekend while I was “at school” down the road…
One thing to note is that the calipers are mounted in a trailing position and not in a leading position as we had them last year… our bad… we had them on backwards! The old APs were set up to be leading but the Baer 6R’s (and, I assume all 6 series) are designed to be trailing (as delivered). While it’s possible to set them up to be leading (the piston sizes determine orientation) we assumed… incorrectly. All better now!
At the end of the day the floater rear weighed about 20 pounds more than the fixed axle – most of that is attributable to the E-brake pieces but the axles contributed a bit as well. While I really didn’t need the extra weight, it’s probably best to have it on the back of the car.
James
1969 Camaro - Dusty
