Old 02-17-2012, 05:41 PM
ccracin's Avatar
ccracin ccracin is offline
Thanks Jimbo. I have already talked to Gus at Cleveland Pick A Part. He is supposed to be getting back to me if he has something. I will check out Schrams. Thanks again.
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 02-17-2012, 06:14 PM
I have a complete 2002 LS6 without accessory drive - but with a ECU - Make me an offer via PM or email if you want to Chad.
It has 3 or 4,000 miles on it but hasn't been run or turned over in 4 or 5 years.
Old 02-17-2012, 06:57 PM
ccracin's Avatar
Ok, so I am going to discuss this engine with Greg. Here is my question with regard to that. What do I have to be concerned with as far as the computer goes? He has the ecm which was most likely from a 2002 Z06. Would it be easier to reflash my ecm with a proper tune or could that one be used? Greg may have these answers as I have not talked with him yet. Just thought I would throw it out there.
Chad
Instagram - @cctek
Old 06-10-2012, 08:38 AM
Not much news here Chad since I sent you that LS6.... I know you had some issues with the heads (stripped bolt holes) etc.
You get that bad boy running yet??
Old 06-10-2012, 10:22 AM
ccracin's Avatar
So you back in the land of the free and the home of the brave? It is in fact running. 175 miles on it to be exact. It is running good. After some research and a very helpful conversation with Mike Norris it was determined that it was plug and play! I have to give props to Mike, I was willing to have him do a reflash, but he said unless I wanted every last drop out of it I didn't need to do that. He said there would be no problem as far as hurting it. It did take a while, as you said the head problem had to be corrected. That turned out to be challenging. It seems a lot of the parts that are part of the stock LS6 cylinder heads are being discontinued by GM. I was able to get a new casting from GM. But, the number one intake valve was bent. I am assuming this happened in the accident that took the Vette's life. This is where the problem was. GM has discontinued that valve. It is hollow and very light. So, unless I could source a new one, I was going to have to disassemble the other head as well and replace all the intake valves. I had been working with PACE performance on all these parts. I can't say enough good about them. Chuck Fitch the manager is a great guy. I recommend anyone dealing with them. He went to GM powertrain direct and struck out. Just when I was going to pull the trigger on taking the other head off, he called and said he found me one. Katech had it. So after a couple weeks of looking I had the valve and got it back together. Then as you may or may not know, to change the engine in a 4th gen it has to come out the bottom. Yea, what a pain without a hoist. So since our shop has an exploded truck all over it, I made arrangements to have it switched at a local shop that does this stuff. That took 2 weeks as racing season is getting into full swing here and he was backed up. In the end, I got it back this past weekend and have been going back and forth to work this week. So far so good. It definitely runs better, but I think there might be a tune in the future as I think I am leaving ALOT on the table with the stock ecm. That will be way way down the road. I have to recover from this. This is just a daily work driver and was an unexpected expense. Thanks for offering the engine up buddy, my search around here was yielding nothing. Very please, plus I learned alot about the LS stuff along the way. Ill be in touch, I was waiting till your whirl wind tour of Italy was over. Hope you had a great time.!
Chad
Instagram - @cctek
Old 06-11-2012, 04:53 AM
What ??? NO pictures of the pull out carnage ?? None ??? Really !!!!!
OK, you asked for it ....
With pleasure, Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 06-11-2012, 06:18 AM
With pleasure, Jim
Jim -- The LS6 motor was a motor I bought several years ago that I had rolling around the "shed" and never used. It was a 2002 Corvette ZO6 wreck pullout. So there's no pullout carnage for that motor.
Old 06-11-2012, 06:42 AM
ccracin's Avatar
With pleasure, Jim
Thanks, appreciate your patience!
Don't worry, I'll get some. I only had time to drop the dead horse off the truck in the garage when I picked the car up last weekend. It's been a busy week. I was out of town 3 days this paste week for work. Then this weekend was my daughter's dance recital. I ain't getting nothing done! Stay tuned!
Chad
Instagram - @cctek
