Old 03-04-2012, 03:06 PM
Blake Foster's Avatar
31 spline will be fine. with street tires. or even drag radials,
i used to have a 600 hp Big Block Ford drag car with 14x 32 rear tires and a tans brake
IT had 28 Spline Strange axles in it for 4 year till i decided to look at them , there was 4 splines of twist in them but never broke.
Save your money.
Blake Foster
www.speedtechperformance.com
Old 03-04-2012, 03:17 PM
John510's Avatar
John510 John510 is offline
Thanks guys looks like I will save the money. I don't plan on drag racing my car.
As far as close ratio T56 I have no idea. It is a stock T56 from a 2000 Camaro
I was thinking a 3.70 gear tracloc should be fine right?
Or should I get a spool?
[SIGPIC][/SIGPIC]
Old 03-04-2012, 04:08 PM
FETorino's Avatar
FETorino FETorino is offline
According to DDperformance's website, the 98 thru 02 camaro T56 ratio's are:
2.66/1.78/1.30/1.00/.74/.50
First gear is like the close ratio in the calculator and 6th is way high.
You could run 3.90 rear and still do 72 @ 1800rpm with a 345 30 18 rear tire. The 2.66 first gear with 3.90 would be like having 4.10 with a T10.
How tall a rear tire do you have. Light or heavy flywheel?
Rob in SoCal
Old 03-04-2012, 06:09 PM
John510's Avatar
light flywheel with 335/30/19 wheels
[SIGPIC][/SIGPIC]
Old 03-04-2012, 10:22 PM
FETorino's Avatar
Don't go spool or tracloc how about a truetrac.
With a light flywheel and 27" tall tire you may like a 4.10 better. Here is another calculator. Choose SN197 2.66 for the trans the gear ratios are the same as yours. Shifting at 2500 puts you at 20mph in first with 4.10s. It would be easy to drive stop n go with the lower gear and with the .5 od you still don't pull a lot of rpm in 6th.
http://www.tremec.com/performance/gear-calculators.html
Rob in SoCal
