Old 03-07-2012, 09:24 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
For me the one of the deciding factors is the location of the key in the column, (if you want a column with a key). Ididit has that weird location that is angled... google the two, it's too hard to explain.
Matt
Old 03-07-2012, 09:47 PM
Tom.A's Avatar
Tom.A Tom.A is offline
I agree with Matt the Ididit has a bunk key location. I have one in my car and the thing that bugs me the most is the movement of the wheel after the tilt is position.
I seem to recall Widowmaker had a collaspable one. I googled it and looks like they have one
http://www.ididitinc.com/ididit_eNew...l_Columns.html
Tom
Old 03-07-2012, 11:10 PM
My Ididit has been known to pop out of position unless it's in the bottom two positions. I called them and they will repair it at no cost. I just need to send it back. I just haven't been motivated to tear the steering column out of my car and shlep it to Minnesota or where ever.
Old 03-08-2012, 08:26 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
If your just looking for a tilt wheel check out this guy on pro-touring or his web site gmtilt.com
http://www.pro-touring.com/showthrea...umn&highlight=
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 03-09-2012, 04:45 AM
71RS/SS396's Avatar
Matt
I think they are now making a column with the normal GM key location.
Old 03-23-2012, 11:32 PM
Camaro Dave's Camaro Dave's is offline
Matt
this used to be my biggest complaint about ididit .... however they finally wised up and fixed the problem , now the key is in the factory location
Flaming River doesnt even include the correct pigtail to install , you need to buy extra parts just to make it work
Old 03-23-2012, 11:51 PM
David Pozzi's Avatar
Anyone had excess lash with a Flaming River tilt Column?
http://www.PozziRacing.com
Old 03-24-2012, 09:53 AM
Matt@BOS's Avatar
Define excess, or excessive? The one in my car has a little. Seemed about the same as an Ididit.
Matt
Old 03-24-2012, 12:51 PM
ironworks's Avatar
Yeap. The tilt just seems sloppy up and down.
Old 03-24-2012, 11:33 PM
Any excessive lash in the upper steering shaft when turning the steering wheel left & right? By excessive I mean enough to be noticed as above normal, - more than a stock GM tilt column? I drove one car that that had enough to bug me if it were mine.
