Old 03-20-2012, 05:29 PM
Ron in SoCal's Avatar
Originally Posted by killer69 View Post
Explain the dril mod please.
http://www.installuniversity.com/ins...r_cylinder.htm
Ron in SoCal
69 Camaro in progress
Old 03-21-2012, 06:30 AM
Payton King's Avatar
Default As explained above is how too
The "why" is GM put a restriction in the factory line. When you are really using the clutch the fluid does not have time to flow back quick enough and sometimes cause a slow release. 1/8 drill bit, flush it out and you are golden. Aftermarket or home made lines do not have this line restriction. Took me maybe 10 minutes to do the entire modification.
