Old 03-24-2012, 02:32 PM
Helical Synchronized Ratios
2.95 2.42
1.94 1.53
1.34 1.23
1.00 1.00
.59, .63, .75, or .90 .59, .63, .75, .79 or .90
Looks pretty decent to me.
That second column is excellent IMO -- didn't see that... only saw this:
Our Street 5-Speed kits are currently available with the preferred 2.94, 1.94, 1.34, 1.00 ratios in gears 1 thru 4.
Old 03-24-2012, 02:43 PM
I think I'll call them and see if they can beef it up a little more for somebody I know.
Old 03-24-2012, 02:45 PM
Dude... that would be killer with your motor.... just don't order the same one that Hobaugh had...
Old 03-24-2012, 03:25 PM
Yep, it would work really well. I just doubt it would last. I did a little research and it sounds like it will be noisy in this configuration as well. I'll call to humor myself on Monday.
Old 03-24-2012, 05:26 PM
badmatt's Avatar
badmatt badmatt is offline
I need to find something soon... My SB2 is itchin to be put in.. and beat on.
I was looking at a Tex T101A but the shift linkage kills me for clearance...
Old 03-24-2012, 05:33 PM
Matt, what are the details on your car and motor? I almost went with SB2 stuff myself... curious to see what you're doing.
The linkage room needed for my car wasn't that bad really.
Old 03-24-2012, 05:38 PM
badmatt's Avatar
Truck is a 97 Sonoma that has been de-airbagged now rides on coil overs all around with a 3 link. ill be reposting a build thread soon.
motor is a strait RCR built motor one of D. Laurences pet motors. made roughly 830 hp. winds to 9800rpm i can post up a pic if you like?
how far does the linkage protrude from the side of the trans?
Old 03-24-2012, 05:45 PM
It's your thread dude so go for it.
I would def be putting a bulletproof trans behind that motor if it were me. Sounds like you are not detuning the motor at all.
What are your plans for this truck? Much street driving planned?
Old 03-24-2012, 05:47 PM
badmatt's Avatar
Looks like I can make a T101A work.. *hits ebay*
mostly street....
some track/auto X
pic of it all together before I pulled it apart for inspection and a new pair of lifters.
Bell housing and clutch.
BTW your Camaro is awesome!
Old 03-24-2012, 06:45 PM
badmatt's Avatar
What about a faceplated TKO600 from Liberty? with the the road race gear set?
Matt.
