Closed Thread
Old 03-25-2012, 11:14 PM
FETorino's Avatar
FETorino FETorino is offline
I complained at Bondurant for 3 days about the crappy 2/3 shifts in the Grand Sport Corvettes with high rpms...
So a T56 shifts like a tractor also?
Rob in SoCal
  #2732
Old 03-25-2012, 11:15 PM
J/K Bro! Time to do some cuttin'
You got it comin....
  #2733
Old 03-26-2012, 02:23 PM
That's hilarious Ron.
Todd you gave it a good run... I believe DSE Kyle had/has a TKO in his 70... is he still running it? I believe he was running a cooler on it as well at one time... or maybe he switched it out for a Magnum?
  #2734
Old 03-30-2012, 10:35 AM
Sieg's Avatar
Sieg Sieg is offline
It's a factory bump stop. I wouldn't want the clutch pedal any higher but I know where you are going....
FWIW:
This put my clutch and brake even and added some free-play. The brake pedal stop in the car is similar thickness to the cut clutch stop.
  #2735
Old 04-05-2012, 09:50 PM
I decided to adapt a set of dual adjustable Afco shocks to the rear of my car. I have reached the end of the rope with my single adjustable Varishocks. I'll never forget Mike Maier's face when I told him that was what I"m running out back. Anyway, to meet my future goals, I need more adjustability. Not only to slow down my weight transfer but to get down the 1/4 on the level I desire. I like the idea of having the same manufacturer front and back. Since my DSE sub has dual adjustable AFCO's this was my first choice. I got lucky and AFCO was able to build me a shock within .1(Stroke was also within .150) of the length of my old shocks and I'm able to mount them to reduce the unsprung weight while keeping the adjustment knobs accessible. That meant I didn't have to cut new relocation brackets. I did have them add a bump stop. I'm sure it will take me a few events to find the sweet spot but it should be worth it in the long run.
  #2736
Old 04-05-2012, 09:55 PM
Does Kelli know where her honeymoon cash is going?
Just asking'
  #2737
Old 04-05-2012, 10:04 PM
She's out galavanting in it right now.(The one on the right)
  #2738
Old 04-05-2012, 10:12 PM
I knew I liked her!
  #2739
Old 04-05-2012, 10:37 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Dang! Does the ad agency for Viagra rent out the cars in your garage for their commercials?
I'll be out in Vegas to beat up on some magical Mopars, or whatever they call their event. You'll be there right? We need to show them what two lightweights can do against those Challengers.
Matt
  #2740
Old 04-05-2012, 10:57 PM
intocarss's Avatar
Just out of curiosity, when you make a pass on the 1/4.... what settings do you run your front shocks at and is your front sway bar connected ??
Closed Thread
