Old 03-26-2006, 12:54 PM
one+g one+g is offline
Default 1988 Monte SS Ls6 -t56 315 rear tire ETC
http://home.earthlink.net/~bzdel/index1.htm
Here is a link to probably the first G-body Ls1 swap- Now an LS6. He did have all the technical details posted but now I cant find all the pages. Anyways, Cool car and I think it qualifies as protouring.
Old 03-26-2006, 02:12 PM
samckitt's Avatar
samckitt samckitt is offline
He is currently working on an LS7 swap in the car.
Scot
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-26-2006, 02:15 PM
samckitt's Avatar
Here is some info on the build:
http://www.montecarloss.com/ubb/ulti...7;t=011560;p=1
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-26-2006, 03:48 PM
Default Thanks for the update
Maybe John can give us some performance figures when its done, and I am curious to how he fit 315's under the rear. Has his frame had the notch like in the tech file on maliburacing.com ? Curious because on the car I had it seemed that 285 was the max width to run on stock frame and tuck into the fender well.
Old 03-26-2006, 04:35 PM
samckitt's Avatar
He did notch the rear frame rails. Also he cut the inner fender wells from another car to widen that area. Also he welded a piece of tubing from one side to the other. I want to do it before it is all over with. I wish Centerline made the stars in 11" widths. I have called them a few times to try to convince them to make 2 of them, but they won't. They said they used to, but not any more. So I guess I will have to get a different brand.
Search on MonteCarloSS.com for it.
Scot
Scot
86 Monte SS
LS2/T56 Magnum
Old 03-26-2006, 07:24 PM
McssGmachine's Avatar
McssGmachine McssGmachine is offline
I don't know how to link, but if you go to the rolling chassis section on there you will see a post called "Mini tub pics" its in there.
Brian
Old 03-26-2006, 07:53 PM
Default link to John's Minitub
http://www.montecarloss.com/cgi-bin/...;f=18;t=001268
Heres the summation and pictures of the minitub to fit the large rear tires on Johns G-body.
For info to add a link to a reply, go to the website you want highlight the address in the address bar. Click on edit, click on copy, go back to your message and click paste to throw it in. Then test it after you post to verify that you got it right.
