Old 04-01-2012, 01:03 PM
Sieg's Avatar
Sieg Sieg is offline
Solder and shrink tube if all else fails.
What guage of wire?
They require patience and still can be frustrating.
Old 04-01-2012, 02:35 PM
dhutton dhutton is offline
I just finished mine. The doubles for the right connector were brass colored in my kit. The one you've shown is definitely the single.
Old 04-01-2012, 07:45 PM
Sieg its either 14 or 16 ga. Its for the tail and parking lights.
These are the two types that came in the bag of terminals for the rear tail light harness. Don't be fooled by the picture of the tinned one it's still not big enough for two wires to fit side by side. The ones for the side marker are even smaller.
Old 04-01-2012, 08:30 PM
Z06vette's Avatar
Z06vette Z06vette is offline
What style crimp pliers are you using? I have the ratcheting type with interchangeable jaws. Mine has 3 different sizes per jaw. I mostly used the med & large for the AAW. The single wire terminal used medium & 2 wire used the large. You really need a heavy duty large set of crimpers for the some of the heavy crimps such as the ALT eyelet. It took me a while to figure this out the first time. One the small brass connector above, I found it necessary to bend the flat tabs so they line up with the others. Also, opening them up as you did will make it near impossible to crimp correctly. If anything they need to be closed slightly. I fit the termninal in the crimpers & sqeeze just one click. This holds the terminal in the pliers so I can insert the wire & hold it with my free hand & sqeeze the crimpers with the other. I also found it necessary to slide the terminal as far out of the jaws as possible or the end would get squashed or bent. On my 69 I installed all those plugs for the taillights as shown in the directions. I'm wiring my 68 firebird now & I did not use all those plugs. I used butt connectors with heat shrink already on them. It simplified everything & made for much cleaner install. I dont see the point of unplugging the sockets when they are easily accessible & come out of the taillight housing in seconds. Sorry for the long reply. Scott
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 04-01-2012, 09:39 PM
Wayne, you need to twist the two wires together.
Old 04-01-2012, 10:11 PM
Sieg's Avatar
This is 16 guage:
Old 04-02-2012, 06:38 AM
Scott I have both crimpers AAW recomends.
Todd I'll give twisting the wires a try again. Could you fit the insulation in the crimp like they say to do? They sent some practice crimps so atleast I had some to try first.
Old 04-10-2012, 08:19 AM
boostin05blacks boostin05blacks is offline
This is 16 guage:
Im working on my wiring kit also and would like to know any more info on these? Id like to buy a pair.
Will this one work from those connections?
http://www.amazon.com/GM-Delphi-Weat...4070909&sr=8-4
