Old 04-24-2012, 02:08 PM
The aluminum hats are for heat dissapation. Aluminum disapates heat much faster than steel.
Old 04-24-2012, 02:16 PM
chr2002ca's Avatar
chr2002ca chr2002ca is offline
Yep, what Greg said. Less heat transmits to your hub which improves bearing life in the hub. Like someone else mentioned above, I also weighed a 2-piece and 1-piece Baer rotor and didn't notice much difference in weight. One other thing to consider if your outside tire clearance is very tight: the 2-piece rotor has a thick aluminum hat which will push your tire out about 1/8"-3/16" versus the 1-piece rotor.
Chris Robinson
1969 Camaro SS/RS, 489 ZL-1 MPFI, T-56 Mag
Old 04-24-2012, 02:25 PM
Forgot to add that it's also supposed to help with rotor warp.
Old 04-24-2012, 04:47 PM
Apogee Apogee is offline
...and there are two main types of performance 2-piece rotors, floating and fixed mount designs. Most OE replacement 2-piece rotors have the same hat thickness as the OE disc it replaces. Average weight savings in my experience is 2 to 3.5 pounds per rotor, which is always a good thing, although at hundreds of dollars per pound, certainly not for every budget.
Fixed mount 2-piece rotors are just that, fixed, where the hat is directly mounted to the disc with high-temp (hopefully), high-quality stainless AN hardware. DBA5000-series rotors use this configuration (as do many Wilwood and other rotors) and are popular in a lot of rally and other relatively dirty applications, and while lighter than equivalent 1-piece rotors, these can still exhibit some issues with "coning" due to the differences in the thermal expansion of the disc and hat.
Floating discs can use a variety of mounting methods that allow the disc to thermally expand with minimal resistance from the hat to doing so. Bobbins, t-slots, radial grooves, etc...they all have their pros and cons, but they all function on basically the same in principals, some just better than others.
Tobin
KORE3
www.kore3.com
