Old 05-09-2012, 08:18 PM
FETorino's Avatar
FETorino FETorino is offline
Originally Posted by Chad-1stGen View Post
I don't get this? How does changing the base but not changing the cam specs gain 60 hp? Was he saying that just having the large roller bearing surface frees up that much HP? Any engine experts able to explain this?
For the same reason not all cams with advertised duration of say 290 deg are the same. The ramps are very different and hence the actual timing events. That's why a starting point for cam comparisons is to use the measurements of duration at .050 of lift.
Mopars used to have an advantage in the flat tappet cam world because of their larger base circle cams.
Roller lifters allow for more extreme timing events and a larger base circle allows you to have even more aggressive ramps without the lifter binding. Optimizing the opening events is what cam timing is all about and the larger base circle gives you the ability to do so. Cam lobes get closer to square. Open to full lift quicker and close from full lift quicker.
Rob in SoCal
Old 05-09-2012, 08:51 PM
Sieg's Avatar
Sieg Sieg is offline
Any smarty pants engine guys care to join in?
Pretty smarty pants for a Ford guy IMHO.
Old 05-09-2012, 09:01 PM
This is real race car stuff. How agressive can you get with that opening ramp. To put it in Laymans terms, how fast can you get the valve near max lift and keep it there during duration? Just like many other things in this hobby, it's a snowball effect.
Old 05-09-2012, 09:08 PM
DFRESH's Avatar
DFRESH DFRESH is offline
And keep the valve train stable with those aggressive ramp profiles. I think Mr. Moderator is using shaft rockers--correct? This new motor is going to be sick. D, will you leave the exhaust the same? Side output?
D
Old 05-09-2012, 09:29 PM
This is what I tried to convey about the lobes staying near max lift (or targeted lift -- I remember Mike sayin 200-600 is the range he cares about, even though we will likely have around .700 net lift.) for an extra 6-8 degrees of duration.
D
Yes, Jesel shaft rockers. Mike says they are pretty old but he can "update" them to be okay to use.
I plan to run same current exhaust. Driver side exit only, and that is key for running Thunderhill where the sound meter is on the passenger side. I hope I can pass. I'll bring the Spintech setup as a backup. Hopefully the new headers will come close to where the old ones ended. I also thought that by running the motor on the dyno with no muffs it would be near reality to my real exhaust on the street/track with only the inserts I have for a few db reduction.
Old 05-10-2012, 08:05 AM
Bucketlist2012's Avatar
Bucketlist2012 Bucketlist2012 is offline
I like a moderator that likes it loud...
If he was running Midas Turbo mufflers, I would be concerned...
Luck is the meeting of preparation and opportunity
Pro Touring 71 Z/28 in training
Soon to be crazy
Old 05-10-2012, 08:12 AM
fleet's Avatar
fleet fleet is offline
Agreed.
