Old 05-13-2012, 05:04 PM
dhutton dhutton is online now
Kent-Moore makes a tool that locks the flywheel. They are expensive though:
http://www.ebay.com/itm/Kent-Moore-J...#ht_1574wt_768
Old 05-13-2012, 06:40 PM
wiedemab's Avatar
wiedemab wiedemab is offline
I was able to get my new (stock) bolt tightened to spec in my C5 when I replaced the balancer, but it was a PITA. I torqued it to spec with the torque wrench and then to get the additional 140 deg. (I thinks that's right - anyway, whatever it was) I had a monster breaker bar w/ a pipe on it.........I had the rear wheels on the ground, e-brake yanked, and it was in gear.
I think the ARP bolts are just required to be torqued to a certain spec. I don't think the stock bolt is supposed to be reused. At least that is what I was told. I think it intended to stretch upon installation -- LS gurus can correct me if I'm wrong.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 05-13-2012, 06:57 PM
Not a guru but the stock bolt is a stretch bolt and should not be reused.
Old 05-13-2012, 08:01 PM
brownz brownz is offline
YEP! never reuse the stock bolt.
I pulled the starter and had someone hold the flywheel with a pry bar against the bell housing and got the bolt real close the the spec.
Old 05-14-2012, 07:25 AM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
Take a spark plug out, insert rope, tighten, remove rope.
John Paige
lab-14.com
Old 07-08-2012, 06:46 PM
rusty63ss's Avatar
rusty63ss rusty63ss is offline
When using this method it is very important to make sure the cylinder being used is approaching TDC on the compression stroke. If not and you get the rope on an open valve damage may occur!!
Old 08-02-2012, 05:13 PM
sjaroslo sjaroslo is offline
does that device bolt in in place of the starter? Having a hard time visualizing it... Thanks.
Old 05-14-2012, 10:22 AM
CFster CFster is offline
A big screw driver will accomplish the same thing.
'67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
'67 GTO LS3 Swap
Old 05-19-2012, 11:23 PM
John510's Avatar
John510 John510 is offline
Use an air gun and you should be good.
[SIGPIC][/SIGPIC]
Old 06-11-2012, 07:42 PM
gray86hatch gray86hatch is offline
http://www.ebay.com/itm/290714524113...84.m1555.l2649
