Old 05-18-2012, 01:30 PM
Lateral-g Moderator
Most modern cars won't allow a neutral drop of any kind and certainly have a reverse lock out when speed is sensed. I may have tried it in a rental car.
Wow that sucks, that was fun.
I think you could find a way to grenade one
Old 05-18-2012, 02:57 PM
onevoice onevoice is offline
About 40 years ago, my first car was a 67 Impala with a powerglide. It went from first to reverse at wide open throttle once at about 50mph. It was a column shift and I was 16, what can I say. It boiled the tires in reverse until I let off. No harm done and it lasted another 100k miles. I would be surprised if a modern car would let you do it, but if it did, I could see it destroying a rear end.
Old 05-18-2012, 04:00 PM
Originally Posted by bigtyme1 View Post
OK, I have a claim at work from a guy who claims his son kicked his tranmission into reverse, The car lifted in the air and shattered the rear casing, This is a 2000 Mercedes SL500. A/T. Now I have seen Nascars slammed into reverse but I know they are built for it. What do you think?
It didn't happen that way.... deny the claim.
Old 05-18-2012, 04:13 PM
ironworks's Avatar
I think most modern cars have a brake pedal lock out that keeps you from doing such. You have to have your foot on the brake to get it out of park and neutral I think.
Old 05-20-2012, 12:18 AM
4mm 4mm is offline
I've purposely tried this on my 2010 Toyota Sequoia while driving 30mph, all it did was make a buzzing sound like the gear teeth slightly grinding, but no engagement. No damage at all, and yes I was able to shift into reverse just like if I was going from park.
Old 05-20-2012, 06:30 AM
Lateral-g Moderator
That took some balls
Old 05-20-2012, 09:08 AM
EBMC's Avatar
EBMC EBMC is offline
Was there alcohol involved in that experiment?
Steve Keefer
Old 05-21-2012, 02:38 PM
rwhite692's Avatar
Have you asked....the manufacturer?
Maybe the system that is supposed to prevent this from being possible, did not do it's job (software glitch?)
Mark I'm sure you won't base your decision on some informal internet polling...
Project update thread here:
My Lateral-G Page
My Shop Build:
Old 05-21-2012, 02:48 PM
TheJDMan's Avatar
TheJDMan TheJDMan is offline
I agree, this would be a question for the manufacturer! However, in any case I would consider it to be an operator error.
Steve Hayes
"Dust Off"
68 Camaro
"Jeremy Clarkson"
Old 05-22-2012, 02:12 AM
4mm 4mm is offline
No balls needed, just a quick reaction to keep my daughter from crashing LOL (I was teaching her to drive).
