Old 05-13-2012, 10:54 AM
scherp69's Avatar
scherp69 scherp69 is offline
Default How do I keep motor from turning while trying to torque crank bolt?
I've installed the ATI balancer on my motor and it says to torque the stock crank bolt to 240 ft/lbs. How do I keep the motor from turning over to get it torqued that tight? The motor/trans are the car and I'm using a Lakewood scatter shield so not much access to the back. Any suggestions would be greatly appreciated.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 05-13-2012, 11:25 AM
If the driveshaft was in and wheels/tires/emergency brake installed and functioning, I'd put it in gear, block the wheels, set the emergency brake and torque it that way.
With that said................... I've never torqued mine to spec on the LS motors. I use an impact and get it tight, and I've never had an issue. I understand that's not correct per spec, and I understand you can probably find people who've had an issue NOT doing it per spec, but in my experience it's worked perfect FOR ME every time.
Old 05-13-2012, 12:37 PM
scherp69's Avatar
Thanks Jody. Maybe I'll just leave it until I have the drive train finished. Might be easier then.
Mike
New Gen Splitters
LS3 and TKO600
Old 05-13-2012, 04:04 PM
dhutton dhutton is offline
Kent-Moore makes a tool that locks the flywheel. They are expensive though:
http://www.ebay.com/itm/Kent-Moore-J...#ht_1574wt_768
Old 05-13-2012, 05:40 PM
wiedemab's Avatar
wiedemab wiedemab is offline
I was able to get my new (stock) bolt tightened to spec in my C5 when I replaced the balancer, but it was a PITA. I torqued it to spec with the torque wrench and then to get the additional 140 deg. (I thinks that's right - anyway, whatever it was) I had a monster breaker bar w/ a pipe on it.........I had the rear wheels on the ground, e-brake yanked, and it was in gear.
I think the ARP bolts are just required to be torqued to a certain spec. I don't think the stock bolt is supposed to be reused. At least that is what I was told. I think it intended to stretch upon installation -- LS gurus can correct me if I'm wrong.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
Old 05-13-2012, 05:57 PM
Not a guru but the stock bolt is a stretch bolt and should not be reused.
Old 05-13-2012, 07:01 PM
brownz brownz is offline
YEP! never reuse the stock bolt.
I pulled the starter and had someone hold the flywheel with a pry bar against the bell housing and got the bolt real close the the spec.
Old 05-14-2012, 06:25 AM
NOT A TA's Avatar
NOT A TA NOT A TA is offline
Take a spark plug out, insert rope, tighten, remove rope.
John Paige
lab-14.com
Old 05-14-2012, 09:22 AM
CFster CFster is offline
A big screw driver will accomplish the same thing.
'67 GTO - LS3, 4L60E, SC&C AFX Package, KORE3 C6 Z06, Boyds PT-09s
'67 GTO LS3 Swap
Old 05-19-2012, 10:23 PM
John510's Avatar
John510 John510 is offline
Use an air gun and you should be good.
[SIGPIC][/SIGPIC]
