I bought a used EFI kit that came in today, I'm psyched. Everything looks good. Accel DFI with all wiring and computers: Gen7 with SFI and Alpha-N fueling. Even has the o2. And my low-pro Eddy TB linkage clears the rails with no spacer. (Sold off the shiny one...I don't like shiny). Drop base air cleaner also clears everything fine. I had to use a 1" spacer on the drop base to clear my fuel inlet on the carb, and the TB is 3/4" shorter than the carb, so I might even end up with more hood clearance with the single plane manifold than I had with the air gap! Bye bye stupid carburetor.
Current setup with the airgap & carb:
I also bought a pair of AFR 195 CNC heads and roller rockers to make the swap from my carb Vortec intake to traditonal SBC EFI manifold. Unfortunately the heads were not the Eliminators, they were the old style. But I got a good enough deal on them that I got my money back after I sold them. Tony at AFR told me the older style would surrender about 30hp to the Eliminators on a 500hp engine. I was figuring maybe 450hp out of my 355, and it proabably would have been more like 430. Not even worth it when I'm making 400 now.
So, since I'm in the market for new heads and 195s don't really cost any less than 210s or 220s...I'm contemplating a build from scratch. I figure if I can sell the current 355 carb to pan with dizzy and fuel pump included, a nice 421ci forged Dart SHP short block would be badass. Skip white has a crazy cheap price on them. 421ci with a healthy roller cam and AFR heads? Should be an easy 550-575hp. Could even crack 600 if I want to get a little crazy with the cam & compression. http://www.ebay.com/itm/SBC-CHEVY-42...&forceRpt=true
Sold the Accel manifold & rails and bought a Hurricane manifold & rails. (Same carb height, but longer runners for better midrange.) It's a ProComp and the casting kinda looks like crap, but I'll clean it up. Came with ugly red anodized rails, but that's nothing a little oven cleaner can't fix. Photoshopped them black and I like the look.
Air cleaner height is actually exactly the same as the current AirGap since the TB is shorter and spacer is not needed. I've got 1" to play with to the cowl.
Sold the 355 to another member on NastyZ28. Glad to see it headed for another Camaro. Also found some good quality used parts on NastyZ28 for myself. I'm loving the LS craze...it makes SBC stuff cheap! Picked up a fully forged 383 short block, studded 4-bolt mains with Edelbrock roller cam (232/[email protected] .575/.584" 112) and a pair of AFR 195 Eliminators for not much more than I got out of my complete 355. Throw the EFI on and it should make an easy 500hp. And it saves me a few thousand vs building a 421 from scratch.
Since the car is apart now, I'm going to go through it completely and finally do the paint job and detail work that has been waiting. This winter I have some Beretta projects to get to before the Camaro rebirth, but I'm hoping to have the Camaro done in a year or so. More power, EFI, new paint...will be like a new car!
