Old 05-24-2012, 05:21 PM
tucks69's Avatar
tucks69 tucks69 is offline
Michael Tucker
Project "Trouble" 1969 Camaro LS2/T56 DSE subframe, quadrilink, 13" wilwood brakes, Rated X Rushforths
1968 Camaro
Old 05-24-2012, 05:38 PM
Musclerodz's Avatar
Originally Posted by tucks69 View Post
Is that due to the 3 bolt collector under the floor? That is low.
Mike Redpath
Musclerodz & Customz
facebook page
Old 05-24-2012, 05:53 PM
tucks69's Avatar
It's a 4 bolt collector. There is maybe 2.5 to 3 inches from the top of the collector flange to the floorpan. I do have the half height sub bushings but .5 of an inch won t help that much.I would like to see a Camaro with the stainless works before I order them, I know the DSE headers will work but that is an expesive set of headers. I always tell everybody else not to do things twice. Only good thing is this is one of two things I would change about my build, the other would be higher end shocks! The car ran great at RTOS with the ls2 to only have 10 miles on it! But I guess I have spent the cash on the rest of the DSE suspension I might as well go all the way! You only live once right!lol
Michael Tucker
1968 Camaro
Old 05-24-2012, 10:53 PM
505camaro69 505camaro69 is offline
The dynatechs will fit the DSE sub with a LS and clear the steering shaft if you use the mounts that set the engine back! BUT they have very little ground clearance with car at a low ride height. I am looking into Stainless Works or DSE headers myself!
I've not seen the Stainless Works LS headers with the DSE sub. Has anyone used this combination?
Old 05-25-2012, 01:55 PM
frankv11's Avatar
frankv11 frankv11 is offline
well I'm still on side lines to see if something comes out of this thread. DSE has me on a corner,
Old 05-25-2012, 05:09 PM
hotrod69camaro's Avatar
hotrod69camaro hotrod69camaro is offline
Lemon's headers. Good stuff
Old 05-25-2012, 07:08 PM
DFRESH's Avatar
DFRESH DFRESH is offline
I have pics of the DSE headers in the DSE sub and can click off a few pics for you if that would help--I can tell you they fit like they should and only slightly hang below the subframe at the collector flange. Ground clearance was a huge item for me---I was thinking shorty headers, but didn't want to give up the HP/TQ. I got mine for 2k---that's quite a grip for a set of headers, i'll be the first to agree.
Old 05-27-2012, 09:00 PM
Lateral-g Moderator
Dont skimp on headers. Get the DSE set for their sub, just one less thing to worry about. I've made mistakes with headers before and it sucks bigtime. From ground clearance issues to redoing the exhaust.
Old 05-27-2012, 10:12 PM
Musclerodz's Avatar
Lemons stainless are actually more than DSE.
Mike Redpath
facebook page
Old 05-28-2012, 08:55 AM
frankv11's Avatar
Il be getting a quote on header material to see if it's worth the savings and effort.
