Old 05-25-2012, 10:13 PM
They had 50cc chambers..............real FASTCAR stuff!!!
I see his Schwartz is bigger than mine (47.5cc)
Old 05-25-2012, 10:16 PM
FETorino's Avatar
FETorino FETorino is offline
Hmm your chambers are so small
Rob in SoCal
Old 05-25-2012, 10:32 PM
Sieg's Avatar
Sieg Sieg is offline
If he had a bigger piston it would be a moot point.
Old 05-25-2012, 10:37 PM
FETorino's Avatar
His piston tops will look like cereal bowls so he can run on pump gas.
Rob in SoCal
Old 05-25-2012, 10:48 PM
Track Junky's Avatar
Dave, be sure to order 9 pistons.......I broke a soup bowl today
Gaetano Cosentino
Old 05-25-2012, 10:56 PM
Sieg's Avatar
Pump gas? I thought they only had E85 in his region?
Old 05-25-2012, 11:22 PM
Seriously though, pump gas with 47.5 cc combustion chambers......is that even possible?
Gaetano Cosentino
Old 05-25-2012, 11:29 PM
Sieg's Avatar
Seriously though, pump gas with 48.5 cc combustion chambers......is that even possible?
Before Todd calls you out on your math again, they're 47.5cc.
Old 05-25-2012, 11:32 PM
Thanks, fixed
Gaetano Cosentino
Old 05-26-2012, 01:28 AM
I see the knitting club had a meeting tonite while I was away.
Don't worry Mike has it all covered... max of -20cc dish and a piston design that he is confident in will net us around 11:1.
The rate I'm going I may say hell with it and say go dome and hit 2 hp per cube.
