Old 06-11-2012, 12:52 PM
snappytravis's Avatar
snappytravis snappytravis is offline
Default Brake Advice 69 camaro
What would you guys recommend for brakes on 69 camaro disc I plan on running 18 inch wheels, I am building pro touring car I also have art morrison gmax frame setup, I would like to know what you guys have and who Is a good person to purchase them from, thanks
Old 06-12-2012, 12:57 PM
69znc's Avatar
69znc 69znc is offline
Default Baer and DSE
I replaced my front and rear with Baer. Front: Baer Pro+14" system, 6 piston calipers on a 14" 2 piece rotor with silver calipers
Rear: Baer SS4+ system, 4 piston caliper on a 2pc 13" rotor with Silver calipers.
Purchased all thru DSE. Great service and advice.
Old 06-12-2012, 10:12 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
Call Tobin at KORE 3 http://www.kore3.com/ he is a sponsr on this site and can/will help with any question you have
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 06-13-2012, 01:32 AM
Sieg's Avatar
Sieg Sieg is offline
Kore3.com GM big brake kit with 7/8" manual master cylinder delivers very good performance at a reasonable price.
325 x 32mm with 18" wheel:
Old 06-13-2012, 11:07 AM
Blake Foster's Avatar
You think with a MaxG chassis brakes at a reasonable price are required?
I would suggest Wilwood Superlite 14" 6 piston or Baer Proplus 14" 6 Piston.
we are a WD for both brands
Blake Foster
www.speedtechperformance.com
Old 06-13-2012, 12:58 PM
Sieg's Avatar
The ZL1 Vette falls in the reasonably priced category doesn't it?
Old 06-25-2012, 08:53 AM
dolf dolf is offline
Check Corvetteforum, they have some killer used brake deals. I just scored a set F/R 4 piston Alcons with less than 20k miles on them for less than half of what I would of had to pay new. They look brand new! I'm pretty sure any vette brake will bolt right up to that chassis
Old 06-25-2012, 05:26 PM
69znc's Avatar
Default Corvette solution
There is a reason you can find good deals on the Corvette brakes on the corvette forum. in a free market it is value proposition. why are they all dumping them in the secondary market??
