Old 06-18-2012, 01:49 PM
makoshark makoshark is offline
I ordered new carbon fiber clutches and spring pack from Eaton through Jegs to rebuild my Eaton posi. I specifically asked for the 18 pack clutch set. I had to send back the first order they sent to me. This time, I did get the right spring kit, but they still sent me a 14 pack clutch set. I'm tired of this. Will this clutch set work? I'm about to go bipolar on Jeg's
Old 07-07-2012, 03:46 PM
I got out today and did some work on the car. Another frustrating day
I was wondering if anyone has had the problem of sliding a new yoke onto a new pinion. I can barely get my Moser yoke to slide onto my Motive pinion. Any tips to get this to slide on more so I can install the washer and nut to pull it on further? Trying to set the pinion preload and get the rearend setup.
Old 07-22-2012, 07:07 PM
What's wrong with this picture? Look at the lower attachment of the coil-over. These are the 3.6" stroke coil-overs from Ridetech with 8" springs. I believe I'm going to have to go with longer coil-overs with 10" springs. Any ill-effects having the 4.1" stroke coil-over on the front? Also, is there any problem with shimming out the steering arm around 1/4"? I'm having interference with the Truturn at the wheel.
Old 07-22-2012, 08:01 PM
Rick D's Avatar
Rick D Rick D is offline
Are you using Ride Tech lower control arms also? I would think that if you bought all the components from them or a vender then you should have the correct shocks? I would call them and see what they say, but yes you seem to have an issues with the shock being to short.
Rick
Old 07-22-2012, 08:18 PM
No, I'm not running Ridetech's control arms. Ridetech didn't seem to be hugely familiar with the ATS/Chicane brackets, which allows for a coil-over with more stroke. I'll have to call Speedtech tomorrow, I suppose, to hopefully get an answer. When I spoke with them in the past, they didn't seem hugely familiar with this particular setup either. They didn't design my front setup and I don't know how much experience they have with it.
Old 07-23-2012, 05:29 PM
sniper sniper is offline
Why not just build a higher lower mounting point on the control arm? I'd do a temporary one and make sure you have the desired travel. Is 3.6" enough stroke?
Old 07-23-2012, 05:46 PM
I have thought of that, but the amount of fabrication to execute that is more than I am willing to do at this point. I did speak with Speedtech today and was able to get more info than I did before. They spec'd the same size coilover that I have on the rear with the AirBar, which is 5.2 stroke, but with 10" springs. That would be the easier solution to this small hiccup, it seems
