Old 06-18-2012, 08:21 PM
chicane's Avatar
chicane chicane is offline
0.008 to 0.020" is the number to shoot for. Tapered rollers can take more pre-load... think carrier bearings... they get more than that easily... but as stated, too much is too much.
Old 06-19-2012, 05:19 PM
Van B's Avatar
Van B Van B is offline
I test fit the passenger side without spacers and it was at bout .012. I am going to bolt it together tonight if it ever cools off outside. We're not used to 95 degrees here in WI.
Jeff
99 Miata LS6
67 Camaro Street Fighter 599 HP L92-SOLD
Old 06-21-2012, 10:57 AM
Apogee Apogee is offline
Is that a Moser #7900 or #7900FM housing end with a GM flange pattern and 80mm bearing bore? If so, the "FM" variant has a deeper counterbore for the bearing by ~.105" IIRC which could definitely be causing your issues if the .200" spacer originally provided was intended for the standard depth cbore. Based on the pictures, this is what I'm guessing happened, however I don't see the spacers in your picture...maybe I'm just being obtuse. A .105" shim instead of the .200" one should fix your problem given you have about .063" end play before and you want about .040" crush IMO on the oil seal which is preloading the bearing.
The SET20 oil seal (SKF#18881) needs a certain amount of crush to properly preload the bearing and minimize axial movement. If you look inside a seal prior to installation, you'll see that it has some little rubber ridges contacting the bearing that measure about 1/16" tall, and these compress fairly readily when you start torquing down the retainer bolts.
Tobin
KORE3
www.kore3.com
Old 06-21-2012, 10:42 PM
That Tobin guy has some good knowledge.
Old 07-19-2012, 12:29 PM
And always willing to help!
