Old 07-07-2012, 08:25 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
How about posting up a few pictures of the process with that Citrus stripper? Seems to be working REALLY well.
Curtis
Old 07-08-2012, 01:40 PM
Sonar Chief's Avatar
Post Using the citrus stuff!
It's funny that you asked ... cuz I just so happen to have pixs of the dash strip. So this is how I did the dash
I first put a good coat of the citrus stuff on (don't use your hand w/ nitrile gloves cuz you don't have a paint brush) and wait bout two hours, wipe the goo off w/ a shop towel and then use the wire brush and cross hatch the area and the paint comes off. I used a fiber disc on the DeWalt to finish the hard areas and it leaves scratches for the epoxy to adhere to.
Here's a couple pixs of the dash undergoing the strip
Put a good layer on w/ a paint brush
Wipe off and then wire brush.
I used a fiber disc to scratch the metal clean
That's how I did it .... if it is too thin and starts to dry it doesn't work as well ... just put another layer on that spot and she's good.
Hope that helps all
Old 07-08-2012, 02:03 PM
Thumbs up Finally got epoxy
sprayed on all the parts, now just the body is left
So at 1000 it's 70 out and the humidity is 67%, thought I was back in CT for awhile, I'm degreasing the parts and I'm sweating like a pig so I wore a t shirt around my head while I was spraying.
I had to get going cuz the humidity was only going up so I put the car in the driveway and hung the fenders and extensions, the dash and the doors and mixed up some epoxy and got going.
Even with the humidity the epoxy laid down nice, only one run
Anyway here is the pixs of the garage full of parts.
Hung all the parts and wiped em down.
Doors ready to go.
Fenders now have epoxy inside.
Fenders and extensions done
Doors look good
Ditto
Dash is done too!
So ... I let them dry and put them back in the boy's bedroom I need to start attaching parts this week cus the boys are flying out in two weeks and I'm sure they will want them outa thier rooms
Parts in epoxy is a good sight, now I just have to do the body, still have some areas that need paint removal.
Anyway that's what I did today ...... thanks!
Old 07-09-2012, 07:04 AM
Steve68 Steve68 is offline
Once again nice work,
careful, the site owner is in to photography too, he might not like your artsy photos!!! just kidding,
the dark one looks cool!!!
Old 07-09-2012, 09:54 AM
Spiffav8's Avatar
Lateral-g Moderator
Thanks for the process and progress pictures. You're making it look easy.
Curtis
Old 07-10-2012, 08:52 PM
Unhappy Found more RUST!
Well now we don't want to piss in anyone's wheaties now do we? Thanks!
You are welcome! I wish it was easy, just gotta keep plugging away Thanks!
Here is what I did last nite ... finished the A pillars and the upper weatherstrip channel and found a little triangle to show the factory people where to put the studs for the molding, thought that was cool
And with the rain gutters cleaned to metal I can see RUST between the roof and the gutter . I know what that means .... replace the roof after POR15 all the reinforcements .... GRRRRRRRRRRRRR!
Take a look.
Stripped the channel to metal, you can see the rust inside the quarter!
Look at the triangles for the studs!
Driver's rain gutter RUST, GRRRRRRRRRRRRRR!
Well almost ready for some epoxy on the body, maybe this weekend I can get the jambs and the sills epoxied and get the door frames hung, we'll see how the week is going first and plan from there.
Old 07-11-2012, 04:37 AM
Time for the handheld sand blaster,and clean that up,
