Old 04-15-2012, 09:55 PM
ProPont ProPont is offline
I second that. Same process I use and never had any problems with using automotive basecoat clearcoat system. It is a must to use a good etching primer.
Old 05-06-2012, 04:35 PM
Guys here is pic of the heads getting smoothed. Do I need to make sure that any sand scratches are totally removed or will the primer fill them in?
Old 05-06-2012, 06:38 PM
elitecustombody's Avatar
I would media blast if all possible or get it hot tanked. I like using Sherwin Williams GBP 988 etching primer in aerosol before paint. And yes, automotive paint will hold up just fine on the block, can't say that for the heads.They will need high-temp paint.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1998 GS400TT widebody
1969 Firebird
1979 Firebird LS3,DSE,Baer
1938 Dodge LC pickup
Old 05-06-2012, 10:03 PM
Originally Posted by ratman67 View Post
the primer will fill them, and you want some scratches to get some physical adhesion. use a self etching primer first for adhesion then a conventional primer, to fill any scratches, finish with 220 grit then your paint system...
Thanks for the input guys! Prior to using the etching primer, what grit would you recommend to used to go over the bare aluminum to create some bite?
Old 05-06-2012, 11:23 PM
180 grit before primer.Do not load on bunch of material,be it primer,paint or clear,it will only create problems.
Elite Custom Body
1998 Supra APU 6spd
2007 TBSS
1969 Firebird
Old 05-07-2012, 10:17 AM
Thanks Jay, I had ordered the DX533 but unfortunately because I live in California it's not available
So any Californians that might have some suggestion I would greatly appreciate them!
Old 07-10-2012, 08:36 PM
I figure I post an update on my son Nathan LS3 project. He finished removing all the casting off the block.
He even did the inside, LOL. Some body needs to take the grinder from him. Greg, you can say this is the "Freakin Cleanest Block In The Universe"!
Here is a in progress shot of the crank case.
Finished.
Next he had it blasted.
Now it's going to the machine shop to make clearance for a 418 forge internals. Any finally painted in a satin gun metal gray.
