Old 07-12-2012, 05:14 PM
Default Vintage air problem versus computer
Have a 72 Chevy with Vintage Air GenIV system.The car has an LS motor and the fan only kicks on at 220 degrees. The problem is that when you turn the air on the fan does not come on unless the motor reaches 220. Well that raises all hell with the compressor because the condenser is not getting any air through it.
Without adding another fan for A/C only does anyone know how I can get the existing fan to come on when the A/C is turned on without screwing up the computer?
Thanks , Kevin
Old 07-12-2012, 06:27 PM
camcojb camcojb is online now
Thanks , Kevin
sounds like you have a binary switch. If you use a trinary switch you get the extra output to turn the fan(s) on whenever the a/c is activated.
Old 07-12-2012, 06:48 PM
parsonsj parsonsj is offline
I like to use trinary switches for that reason too. Vintage Air sells 'em.
http://www.vintageair.com/2012catalo...Page%2087).pdf
John Parsons
Old 07-12-2012, 07:06 PM
i put a trinary switch in with the intention of adding another fan (pusher) in front of the condensor. I did'nt know I could tie it into my existing fan. Any help would be appreciated.
Thanks, Kevin
Old 07-12-2012, 07:09 PM
Follow the link I posted above... it has a wiring diagram and everything.
John Parsons
Old 07-12-2012, 07:22 PM
Thanks John I appreciate your help!!
Kevin
Old 07-19-2012, 07:36 PM
Z06vette's Avatar
Z06vette Z06vette is offline
Not sure if you had a factory harness reworked, or what computer you have. I'm using a modded factory Fbody harness with factory computer. You can have it tuned to turn the fans on earlier. Also, there is an AC feed that you can hook to the blue wire on the VA harness for the compressor.. This will turn on the fans as soon as AC is turned on. Or use trinary switch as mentioned above.
69 RS LS3/T56
68 firebird vert LS1/4L60E
67 RS LS2/T56
Old 07-20-2012, 08:13 PM
I could be wrong but what if the compressor circuit turns on the fan and when computer sees the engine temp reach 220 degrees and turns on the fan circuit.Isn't that a major problem.........?
Old 07-20-2012, 08:16 PM
nope.
Old 07-21-2012, 07:09 AM
They both work via shorting (switching) the ground circuit... once it's a circuit it makes no difference which one is causing the switch.
