Old 07-14-2012, 07:09 AM
coolwelder62's Avatar
The Roadster Shop,Has built prob,one quickest PT rides around.This run's and Drive's better than most Car's.Build quality is Outstanding also.
Old 07-16-2012, 07:11 AM
Chafin Chafin is offline
Mike Losh makes some pretty nice inner fenders for c10's! check him out at http://www.facebook.com/pages/SloshTubz/174527065934455
Love yalls work by the way!
Old 07-16-2012, 03:27 PM
Roadster Shop's Avatar
Supporting Vendor
RoadsterShop.com
Good stuff Chris
Trucks are posting numbers, can I assume partially due to weight and weight bias?
The weight bias is actually a disadvantage. We ended up adding almost 200 lbs and a larger gas tank to the back of the truck in order to get closer to a 50/50 weight distribution. The truck tips the scales around 3,600 lbs so it is no lightweight.
Originally Posted by GRob View Post
I think the enormous tires under it would be one of the main factors.
They are wide vehicles to begin with so there is a lot of room for tires. We are running a 345 front and rear with out any body mods (except for mini tubs and removing the inner fenders.
Thanks for the info, but I don't think they will offer the tire clearance that we need. We will eventually fab something for the truck when time allows.
www.roadstershop.com
Old 07-16-2012, 03:28 PM
Supporting Vendor
RoadsterShop.com
Thanks Scott.
