Old 07-15-2012, 01:38 PM
coolwelder62's Avatar
Mark,What is the spacer for between the bellhousing and trans.Is the clutch setup thicker than stock.Wiring is extra clean.
Old 07-15-2012, 01:43 PM
Beautiful work on the wiring, I love details like that.
Old 07-15-2012, 01:52 PM
Stielow's Avatar
Stielow Stielow is offline
Originally Posted by coolwelder62 View Post
Mark,What is the spacer for between the bellhousing and trans.Is the clutch setup thicker than stack.Wiring is extra clean.
The spacer is .850" thick to allow the stack up to be correct to run a LS9 twin disk cllutch in front of a TR6060 with a 2002 style bellhousing. D&D Perfromance made the spacer and sells them.
I'm on the edge on the stock LS9 clucth but it drives great with very low effort and a great feel.
We build all the wiring from scratch. If you start with a GMPP LSA harness it is much easier.
Ryan Kuhlenbeck also wired Red Devil and we used that as a templete for this build.
The VanNus's (Dutchboys Restoration) is starting to shoot color tomorrow so I'm getting closer to getting the car back.
Mark
Old 07-15-2012, 02:14 PM
Rick D's Avatar
Rick D Rick D is offline
Mark the wiring looks great! Question for you how come you do not run a scatter shield?? So when are we going to see the color???
Rick
Old 07-15-2012, 03:16 PM
Jtomas801's Avatar
Jtomas801 Jtomas801 is offline
Hi Mark,
Did D&D performance do any tricks on the inside of the transmission, or is it stock from the factory? Also I see an oil pump for the trans, are you just using the fill and drain ports to remove the oil or is there some sort of spray bar in there?
The car is coming along nice hopefully I will be able to see it in person one day.
Thanks,
Jon
_______________________________________________
Jonathan Feltis
69 AMC Javelin - Back in Progress.
Old 07-15-2012, 10:33 PM
67XR7's Avatar
67XR7 67XR7 is offline
HEY Mark, where do you buy all your wiring blank plugs and etc.? I'm still using GM weather pack stuff but sometimes I need more then 5-6 slots.
1965 Chevelle, Pm me if interested in wheel tool rental
Old 07-15-2012, 11:11 PM
56pickup's Avatar
56pickup 56pickup is offline
Looks great Mark!
Tyler
Old 07-16-2012, 07:31 PM
carbuff's Avatar
carbuff carbuff is offline
Mark,
From the pictures, it appears that you are running the stock bellhousing, unless that was just for mockup. Is that correct? At the power levels you are making, do you not think you would want something stronger? Or is your opinion that the stock bellhousing would be sufficient in case of a clutch failure?
Also, on your transmission cooler, I don't know what transmission temps are supposed to be, but I think I just read that the Weldon pump is thermostatically controlled. Is that correct, and do you run within that window, or do you control/override it somehow?
Finally, what size lines are you running to/from the trans cooler? I would think that a heavy weight oil like that would need larger lines, but I think I read that the pump is set up for -6AN lines?
As always, appreciate the education!
Old 07-16-2012, 06:02 AM
ma73z's Avatar
ma73z ma73z is offline
I'd also like to know where to buy them.
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Old 07-16-2012, 06:52 AM
JMitch19's Avatar
JMitch19 JMitch19 is offline
I can't answer for Mark, but the company I work for does some GM harness work for the aftermarket. We have found powerandsignal.com to be your best bet for higher quantity orders and mouser.com to be the best for low quantity.
Jason Mitchell
1971 Camaro 416 LT1 Project
