Old 07-24-2012, 07:21 AM
-Freak-'s Avatar
-Freak- -Freak- is offline
Default 1970 Pro Touring DAR/T
I was nudged into creating a build thread.
So the story goes...
Once upon a time I had a 71 Dart that I turbocharged and was going to do body work on it over the winter. After removing a few panels and fenders, the car was diagnosed with cancer and had 6 months to live.
It was sent down the road and I picked up a cancer free 70 Dart from Arizona to start a new build on.
As you will see this build took and entirely different direction then the last build.
Delivery picture from 6/10
5/11
8 3/4 diff, Large Bolt pattern hubs and wheels, Disc front brakes.
And then the tear down started so it could go on the rotisserie.
Found 2 build sheets.
Back seat.
Under the carpet.
1970 PT Dart - In progress
1971 Turbo Dodge Dart - Sold
Old 07-24-2012, 07:24 AM
-Freak-'s Avatar
Been looking all over for a 46RH. Found a few, all but one were to expensive and trashed. Went and checked out the one today at the bone yard but it turned out to be the non lockup version. I did however score a 42RH.
Its not as stout but it should do the job for a few years.
bye bye 904TF, hellow 4 speed OD!
We are doing this build at my friends shop.
http://www.gcrods.com/index.html
USCarTool SFC's were fitted.
Old 07-24-2012, 07:26 AM
-Freak-'s Avatar
Had the bottom of the car sand blasted for $200. BEST $200 I've ever spent!
Only found one problem spot.
Rear passenger trunk area.
Old 07-24-2012, 07:28 AM
-Freak-'s Avatar
Making room for a fuel cell.
Sub-frames installed. Just need to be grinded and seam sealed.
Old 07-24-2012, 07:31 AM
-Freak-'s Avatar
Reilly Motorsports spring relocation kit was installed.
Minitubs
Patch panel in the trunk to replace the only rotten spot i've found on the car.
Old 07-24-2012, 07:35 AM
TomM's Avatar
TomM TomM is offline
Default Sweet...
Nice job so far. It sure is good to have a solid car to start with....keep up the good work...
T,
