Old 08-11-2012, 01:50 PM
Originally Posted by Chad-1stGen View Post
I'm stuck in NorCal.
You in Sac, or the bay ?
Old 08-11-2012, 03:21 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
I'm sure any of us SoCal people will be glad to go drive it home for you HELL we'll even fill her up with fuel !
That is what I love about this site. Everyone is so generous!!
I'm in Sac. Driving the long drive home with the boat tomorrow.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 08-15-2012, 11:02 AM
Picked the car up on Monday and got back out in the garage last night.
Exhaust sounds great but I've encountered new gremlins (at least I hope they are gremlins and not major problems).
The main thing that prevented the car from being driven in the past was front tire clearance and interference of one of the two pinion down bars on the rear end. After thrashing on other parts of the car I decided that the one pinion down bar was strong enough for a mild drive and threw my old front tires on and took the car for a real drive (as opposed to loading it on/off trailers).
It was not a confidence boosting drive. After warming up the oil I was getting 20 PSI at idle and 40 at high RPM. I also have significant engine vibration above 1500 RPM.
I am hoping I did the noob LS move so many others did and screwed up the oil pick up tube o-ring install when I swapped to the Autokraft pan and that is my oil pressure problem. If not then I don't know what to do next?
I am stumped by the vibration. It's 100% related to engine speed. Will vibrate in neutral sitting still in the driveway when you rev up the motor. vibrates driving at speed until you push in the clutch and/or shift into neutral at which point the vibrations are gone.
Since it was a new crate motor (did sit for 3 years before being run), new RAM flywheel and GM LS7 clutch I'm not sure how to diagnose it. I'm guessing it has something to do with the flywheel/clutch. Would bell housing run-out effect this? Pomona Valley Customs assured me they checked it and it was fine but after seeing their other work I have my doubts. Can you screw up an LS7 clutch install and cause vibration but otherwise have a good working clutch? What would you guys check?
I was supposed to participate in the Super Chevy Handling challenge but after last nights voyage there is no way I can make it.
Old 08-15-2012, 01:41 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Sorry to hear about still more glitches.
Unless PVC has a fixture with a round hole concentric with the crankshaft (like the McLeod adapter plate), I don't know how anyone checks the run-out on a T56 bellhousing.
That said, I'd look to the flywheel/pressure plate. I don't think disengaging the clutch would eliminate vibration caused by excesive bellhousing run-out.
Old 08-15-2012, 03:36 PM
Thanks Mike.
I actually never tried revving the motor with the clutch. I was attempting to describe that the vibration is engine speed dependent only. I will try revving with the clutch in to see if that impacts it at all.
My understanding is you should check all bell housings and that you buy replacement alignment dowels to get proper run out.
Old 08-15-2012, 04:11 PM
I'd look at the engine vitals first in regards to the vibration. All 8 firing, fuel pressure, engine tune, etc...
My stock LS2 makes 28-30 psi at idle hot. What weight oil are you running? Mast may loosen up their clearances and that could require heavier oil to get a pressure that makes you feel fuzzy. 50-60 psi at redline should suffice, hot.
Old 08-15-2012, 04:37 PM
re: oil pressure Mast did confirm my readings sounded a bit low. I would generally agree 50-60 at redline is good. I'm not running the motor at redline yet but 4K it was right at 40 which is far lower than any of the LS equipped vehicles I've driven and I'm used to motors reaching peak oil pressure or at least high oil pressure far before redline. It currently has the Mast recommended 10-30 Valvoline racing oil in it with EOS additive. I'm probably going to drop the pan and check the o-ring no matter what.
I haven't touched the tune since it's tuned at Mast and they do dyno the motors before shipping. I used to check for all cylinders firing by pulling a plug wire one at a time with the engine running. What is the non cave man way to do it lol?
Currently don't have a way to check fuel pressure but will look into that. I have a hard time seeing fuel pressure doing vibration while the motor otherwise pulls fine and drives fine.
I will add the motor pulls plenty hard with the limited drive I did. Even part throttle mild driving up to 3K RPM's shows this motor is far more powerful than my old zz4 350.
I get more vibration through the steering wheel (no more rag joint, uses u joints) than I get riding through the handle bars riding my 88TCB Harley. My side view mirrors shake like a Harley too...
Old 08-15-2012, 06:41 PM
Mkelcy's Avatar
Thanks Mike.
True, but the T56 specific bellhousings don't have a round surface that's concentric with the crank. The bellhousing follows the shape of the transmission. That's why you need some sort of fixture to check runout.
I was trying to say that I doubt that the bell housing could be so misaligned that you get a bad vibration, yet have the vibration compeletely disappear when you depress the clutch with the car moving. The input shaft is still inserted into the pilot bushing and is still hypothetically being whipped around if the bellhousing is misaligned. Again, I'd look at the engine and the flywheel/pressure plate. Was the pressure plate new and zero balanced?
Old 08-15-2012, 07:49 PM
Fuel pressure is crucial with fuel injection. I wouldn't drive it again until you are able to monitor it. An engine in bad tune will vibrate like crazy.
