Old 01-21-2012, 08:16 PM
patoke patoke is offline
Default Ls3 with tvs2300 magnachager in 1971 skylark
Hi guys, I have an ls3 with a tvs2300 magnachager that came out of a 2010 camaro that I want to swap into my 1971 skylark. It didn't come with any accessories as the guy keep them for the motor he put back into camaro. Does anyone know if I will run into issues installing the engine with this blower into the car and also what accessories should I use, corvette, aftermarket?
Old 01-22-2012, 07:56 AM
1969x11's Avatar
1969x11 1969x11 is offline
http://ls1tech.com/forums/conversions-hybrids-28/
Old 01-22-2012, 09:35 AM
rocketrod rocketrod is offline
Don't make this harder than it needs to be, talk with the seller and see exactly what accessory drive setup he had and go buy that.
Rod
1969 Camaro - LS2/4L70E
Old 01-22-2012, 03:04 PM
Originally Posted by 1969x11 View Post
Thanks for the link. I will do some searching.
Old 06-18-2012, 08:51 PM
edge04 edge04 is offline
when you look into it, look into an 8 rib or bigger system as you don't want belt slip and they are known for it. You planning on running a/c?
Old 06-18-2012, 09:21 PM
Musclerodz's Avatar
Wegner has a front drive setup if you want to go aftermarket.
Mike Redpath
Musclerodz & Customz
facebook page
Old 06-19-2012, 04:11 AM
that is a nice kit and built for the 2010 camaro set up. What is nice about it is that it is a 10 rib but even better is that the SC runs off it's own belt and all other accersories on another.
What kind of power you looking to make? That kit may be over kill.
Old 06-19-2012, 06:07 AM
dj3 dj3 is offline
Camaro5 is always selling used blowers and it would be nice to know what will work. I have been tempted by some good prices over there, but not sure how much it will cost to get a drive system to work.
Old 09-18-2012, 01:24 PM
paydirt paydirt is offline
I've got a vortech T trim on my LS3 running about 7 psi on the 6 rib setup with zero belt slip issues. If you plan on running around 10 psi you should be okay with a regular 6 rib setup. You shouldn't have any issues running regular corvettes drives.
Old 09-18-2012, 01:31 PM
I have the TVS2300 on my 2010 camaro and running 9lbs and have NO issues with belt slip with the factory setup.
You need the accessory drive and water pump from the 2010 camaro. Vette stuff wont work with the Camaro supercharger as the spacing is different. have to decide if you want aftermarket or the "truck style" accessories the camaro comes with.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
