Old 10-02-2012, 02:28 PM
68protouring454's Avatar
machine a steel sleeve that will accept the moog or pfadt/howe ball joint, done...
Jake's Rod Shop
Old 10-02-2012, 02:30 PM
Jake, don't be a stranger around here.
Old 10-02-2012, 11:48 PM
Moparigno Moparigno is offline
I never did it before. So I guessed that spending few bucks to purchase a sleeve will worth the hassle..
what is the rule of thumb for a press in ball join ? I mean, what tickness I have to consider as acceptable interference surface ?
Paolo from Italy:
'70 Challenger R/T 383 Hemi Orange
'70 Barracuda GC convertible 383
'65 Shelby Cobra 427 Replica
Old 10-13-2012, 11:37 AM
David Pozzi's Avatar
Since the Corvette spindle is Aluminum it is thicker than a steel spindle in the tapered socket. I would stick with a C5 or C6 ball joint, others would probably be too short in the taper. The upper a arm socket is .790" deep.
Corvette lower ball joint hole in lower A arm is 1.045" thick. I don't have a stock Corvette spindle to measure the lower ball joint socket depth but I do have the LG Racing billet spindle which is 1.525"
http://www.PozziRacing.com
