Old 10-15-2012, 07:23 PM
takid455 takid455 is offline
Some more final build shots.
Some underside shoots during the build. Looks about the same today with more parts added.
Dash gauges
Trunk
Sub yet to be installed and wiring finished.
With 17” spare to clear brakes. 04-06 GTO/ Manaro
Old 10-15-2012, 09:27 PM
89 RS's Avatar
89 RS 89 RS is offline
Great looking Trans Am, really like the motor.
Corey
1989 Camaro RS
Old 10-16-2014, 06:48 PM
Projects are never done and this one is no exception...well, its still being built according to the overall plans created 10yrs ago. Wow..10 years!! About 7,000 miles on the build to date and loving it. For inquiring minds MPG city/ fun time is 12, Highway 18-19. Hopefully this will improve as a new EFI system will be installed over the winter in place of the old Holley Projection 4i. It’s been good but cant feed the motor which was anticipated. At the time , I didn’t care for the aftermarket systems and had this so on it went.
Currently the build is somewhere in the phase 3 & 4 of the overall plan. This year’s updates included:
16”/12” dual brushless fan system by Delta PAG
Adjustable coilover system with ride height adjustability by PTFB
C6 Z06 brakes w/ DBA slotted rotors
Baffled fuel tank w/ in-tank pump. My original tank w/ 4th gen Fbody unit worked well, but starved for fuel around long turns w/ ¼ tank. This is one of those things that happens as aftermarket steps up.
Embroidered floor mats
Show / outing shots
With up and coming Bid Bad Olds.
Back to the fun
Fan set up. 2800 CFM vs 4100 CFM. Better shroud design and overall flow of air through radiator. Engine doesn’t get warm as it once did.
Big boy brakes.
Had the base vette brakes prior and they are a good improvement over stock. These are way better than stock. Makes driving stock brake cars feel as if something is wrong. Def require 18” rims. Had to clearance the front calipers a touch for the 3pc bolts. Direct bolt on otherwise.
New front suspension setup. This allows one to PROPERLY set the coil over so the shock piston is approx half way compressed in the body at ride height. Ride height is then adjusted via jack screw accessible in engine bay. Shocks are double adjustable. Different are were required as the GW arms interfered with the upper shock mount. Difference is dramatic. Car rides much smoother and feels confidently panted to the road. Old coilover setup was OK but could never get it adjusted.
OE mount
After Plasma, sawzall & grinder
Mocked up
Getting there. Stuff gets dirty after use. As much as I clean this car, I was surprised how much and where dirt found its self during disassembly.
All installed and ready to roll
Rears
Winter project is an EFI system I am making myself. Will be tunable by anyone that can tune any late model GM product. System should work on any engine platform with a few platform specific parts. All parts will be avail over the counter if needing replacement.
Old 10-17-2014, 02:15 AM
Rick D's Avatar
Rick D Rick D is offline
Nice job, love the up grades. So who makes that front setup? I like it! Also cant wait to see your EFI.
Rick
Old 10-17-2014, 06:15 AM
Dave @ Pro Touring F body makes it. This is one of his prototypes...I was ginnea pig. Production unit is a little easier to install as it uses the UCA bolts for alignment. Cutting and grinding remains the same effort.
Anxious on the EFI system myself. Works like a charm on paper and theory!
Old 10-17-2014, 06:07 PM
Really glad to hear you're out enjoying the car. Still one of my favorite builds.
Old 10-19-2014, 08:04 PM
instro84's Avatar
instro84 instro84 is offline
nice T/A, make me wish i still had my 75.
Old 08-02-2016, 06:28 AM
Doing some more updates/ upgrades and got some print in the meantime! Woot!
http://www.timelessmuscle.com/featur...e-golden-bird/
Old 08-02-2016, 06:57 AM
Congrats! What changes have you made?
