and a few more
in one of the pics with the wheel siting on amade up stan is the ride height
iwould like to finish up with but i have encounted a few problems with the airide bar setup witch i will get to shortly(hoping some will have soe ideas how to rectify this)
and here a few more of the rear end 9inch and as you will see with the standard spring perch sits toclose to the end of the axle which in return i can not fit a disc with an internal e brake setup so i am hoping some one might know of a bracket i can use to eliminate the spring perches with out having to change out the lower arm as well
