Old 10-23-2012, 06:02 PM
clill's Avatar
clill clill is offline
I would do all motor or do a Eaton style supercharger.
Old 10-23-2012, 06:14 PM
67goatman455 67goatman455 is offline
an eaton style is going to heat soak really bad. not very good for a road course i dont think
Old 10-23-2012, 06:52 PM
that would depend on how well engineered it is.
Old 10-23-2012, 07:10 PM
any recommendations/ experience with them? any help to some good answers is appreciated!
Old 10-24-2012, 07:06 AM
SuperB70's Avatar
SuperB70 SuperB70 is offline
Turbo is great, just the damm lag and the heat load. And with just one turbo the drivebility is not so great on race applications. It more or less on/off. Softer power output by having two turbos.
Instead of useing Eaton, maeby you could use twin screw like Kenne bell, then build intake to house four Laminova intercoolers.
http://www.laminova.se/technology/intercooler
They are simply the best IC in the world.
I builded a big Hemi with a KB twin screw, blower factory told us that intercooler is not needed else than marine and tractorpulling applications.
But there is nothng wrong get your intake air temp down..
I'm currently playing with idea to build for laminova IC intake to my twin screw V10.
, Juhani
Old 10-24-2012, 08:34 AM
GrabberGT's Avatar
Depending on your experience level and goals for the car, I'd say N/A. Autocross-wise, all the major players are N/A. Ridetech, DSE, Posi, Hobaugh, No-Limit... and with the exception of Maier (NASCAR 825hp) I think they are all relatively modest on power around 550hp. I think the important thing is to have a broad power band and a matching final gear ratio to get the most out of it.
Im still new to the game and learning how to use the little power I have 350-400. My last Autocross, I was drifting all over the place. Mine comes in late and my gearing leans towards hwy miles. It should be plenty for autocross though if I switch to a higher rear gear.
Chris
Its not a Vega!!!!
Old 10-24-2012, 10:35 AM
Agreed on your last sentence.
Although most of those players you listed (with the exception of the No Limit truck) have quite a bit more than crank 550hp.
Old 10-24-2012, 10:43 AM
clill's Avatar
Stielow's last three cars were built with Eaton style superchargers and all work great on the road course.
For autocross you are fighting for every little inch. and I think any lag from a turbo will kill your times.
Old 10-24-2012, 04:48 PM
well, i guess a change to a N/A build is in order unfortunately. I have been very excited about the sound/ feel/ and fun of a turbo for a couple years now.
Maybe two small turbo's wouldn't be so bad with lag?
I dont really see the point of going with a super charger because it seems that it would be more cost effective to go N/A. Since this is my first build for road racing/ auto-x i dont want to dump a lot of money into something that i may not like on the track.
Hopefully i wont lose all my motivation because of this change
Old 10-24-2012, 05:19 PM
N/A is the easiest way to go, especially for the above use, and trying to keep the cost down. Any forced induction adds significantly to the cost.
