Old 11-05-2012, 07:56 PM
zcrz zcrz is offline
Default Tko 600 or t-56
Planning my ls swap. I have a tko, should I use it or sell it and go 6 speed?
Old 11-05-2012, 08:28 PM
FETorino's Avatar
FETorino FETorino is offline
Some more info would help.
Which TKO?
How much hp and torque does your motor have?
Do you plan on shifting above 6k rpm?
The T56 is larger how much tunnel modification do you want to do?
Rob in SoCal
Old 11-05-2012, 10:28 PM
I wouldn't put a tko600 in a tonka truck.
Old 11-05-2012, 10:40 PM
I knew you'd be on this thread before the day was done.
Old 11-05-2012, 10:49 PM
FETorino's Avatar
They make a great truck trans. Granny low tow gear and really tall 5th. For a cruiser that shifts below 5k they are fine.
Rob in SoCal
Old 11-05-2012, 11:00 PM
I agree, for the average hot rodder they are just fine. Notchy but bullet proof. Notice the I in my response.
Old 11-06-2012, 04:47 AM
The transmission I have is the tko 600, like the thread says it will be a stockish ls2 or 6.0. Just deciding if I can use some of what I have. I am the average hot rodder. Just looking for driveabilty.
Old 11-06-2012, 06:39 AM
dj3 dj3 is offline
TKO is a vibration prone, sloppy shifting, and is the worst transmission I ever bought.
Old 11-06-2012, 08:53 PM
64duece 64duece is offline
I've used both and both worked well. The T56 feels a a little closer but, the TKO600 was a tad stonger in 1st due to the steeper 1st gear.
Dennis
Moore Racecraft
Old 11-07-2012, 05:08 AM
for a stock ls2 would you go TKO for fitment?
